Old 07-27-2017, 05:57 PM   #1
Donedidit
Donedidit is on a distinguished road
Default 2004 vue brake light
Hi all.
I'm new to the site so bare with me. So i having issues with my brake lights. All three are not turning on. I have checked the brake fuse under the hood as well as the cruise/brake fuse inside near the passenger leg, both are fine. In addition, i have checked the cruise switch and there is power there but i have no power at the brake switch.
Also, not sure if it is related but my battery is draining even if the car is off and all lights are off.
Thanks in advance.
Add to Donedidit's Reputation
Rate the quality of this post and help Donedidit reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Donedidit is offline   Reply With Quote
Old 07-27-2017, 08:35 PM   #2
Default Re: 2004 vue brake light
Here's a wiring diagram to help. 12v should be live from the 15 amp BRAKE Fuse to one side of the brake switch.
Old 07-27-2017, 09:13 PM   #3
Donedidit
Thank you for the quick reply and diagram. So im not getting power to either wires on the brake switch when engaged. Any idea what that c3 and c100 connection are so that i can trace it back to the fuse and see if there is a bad connection along the line. Thanks again.
stuck in park, check engine light, brake light flashing Wemble Ion General 8 02-08-2014 04:38 PM
parking brake switch light and service light GMjonn S-Series Tech 1 01-18-2014 03:51 PM
left and right brake lights don't work but centre high brake light works. microsat S-Series General 15 01-08-2014 10:44 PM
check engine light and antitheft light 2004 L300 jonus311 L-Series Tech 2 01-31-2009 08:55 AM
'95 SL1 Third Brake light works tail brake lights dont' DazMan S-Series Tech 3 03-10-2005 12:20 AM
