Old 07-27-2017, 08:00 AM   #1
Shalkar
Shalkar is on a distinguished road
Post 1996 Saturn SL2 4-DR Sedan
Vehicle: 1996 Saturn SL2 4-DR Sedan
I'm pretty well S.O.L. if y'all can't help me. I have a situation here where somebody had lost the keys to this vehicle, tried (poorly) to hotwire it, and now I have an entire steering column as the replacement part. How do go about this? They had mutilated the ignition cylinder so bad that it was rather easy to take out. Only God Almighty knows what is what with these wires. So I figured just replace the entire steering column... It was also the only option from my closest junkyard. lol
Preferably a step-by-step guide with one, or two pictures for each step. Beggars can't be choosers though, and I just need to get this done before I get my rear end handed to me for not getting it done in time. I had searched, and searched in my area (that being any place I could find within fifty miles) for any kind of help. I could barely find the replacement steering column.
Last edited by Shalkar; 07-27-2017 at 08:02 AM.. Reason: Added vehicle details. My bad.
Add to Shalkar's Reputation
Rate the quality of this post and help Shalkar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shalkar is offline   Reply With Quote
Old 07-27-2017, 08:42 AM   #2
trottida
trottida's Avatar
Default Re: 1996 Saturn SL2 4-DR Sedan
If you're savvy with Torrent files you can obtain the factory service manual which should have the steps. Search for "GM Official Service Manual Software, 98-04" & "Torrent".
The file will install an instance of a virtual PC with a Windows XP OS. The GM Manual is on the XP desktop.
96 and 98 S Series are pretty much the same with not much variance.
Current rides
:canada:
Add to trottida's Reputation
Old 07-27-2017, 10:29 AM   #3
billr
Clarify: Is this *only* a column replacement, or did the wiring external to the column get damaged and need repair? If the harness didn't get damaged, reconnecting to the replacement column should be fairly easy, as long as the column is the same year.
Add to billr's Reputation
Old 07-27-2017, 11:40 AM   #4
^^^Clarify. The actual complete column assembly replacement is a simple straight forward job. Need to know what you have as a replacement assembly and what is left of the car wiring.
This can be fixed and the FSM info is not overly complex or lengthy.
Depending on exactly what you have as a replacement assembly will determine what is required for the remove-replace operation.
07 Saturn Ion 2 Sedan 07saturnion2 Ion Tech 6 06-15-2012 06:00 PM
FS: 1996-99 sedan door, quarter pnl, tail light. atikovi Classifieds 0 01-01-2005 10:35 AM
Loaded ION 3 Sedan vs. Base L300 sedan Caprice General Saturn Discussion 32 02-26-2004 02:29 PM
93 Saturn SL Sedan JeepGC96ZJ Classifieds 4 04-26-2003 09:16 AM
Saturn Sport Sedan. Who's with me? BradJK Ion General 3 01-11-2003 06:14 PM
