Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 07-17-2017, 06:58 PM   #1
Kim p
Kim p is on a distinguished road
Default 97 saturn oval dirt track race car problems please help
Hello everyone and thank you in advance. I have a97 saturn 5 speed tranny. It is a dirt track race car. It goes on my trailer and on the dirt no asphult. I have some questions, 1. How can I turn off the traction control? Every time I go into a corner it loses power. Also is there a way to up the rev limiter to more than 4500rpm since it red lines at around 6 even if I could get it to 5500 I'd be happier. Also this last race my gas cap got broke and it instantly list most it's power and started studdering and cost my the race it barely ran after that it would idle done but not rev and I couldn't let off the clutch to move. Any help would be great. We race oval dirt track derby style smashing ama crashing. This is my first saturn ever. Its got the 1.9 L motor
Add to Kim p's Reputation
Rate the quality of this post and help Kim p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kim p is offline   Reply With Quote
Old 07-17-2017, 08:06 PM   #2
Default Re: 97 saturn oval dirt track race car problems please help
Traction control is part of the anti lock brake system (ABS/TC). Simply remove the abs fuse(s) to disable abs and traction control. ABS and TC are all part of the abs unit controlling when abs or tc activates. Removing power to the abs unit completely disables with plain braking still available. The brakes work regardless of whether or not abs is enabled or disabled. The abs light turns on to alert you to loss of abs. If the light is a problem, remove the instrument panel and remove the lamp or cut one the the led circuit lines to kill the light.
Old 07-18-2017, 11:39 AM   #3
Kim p
Thank you I will do that.
Saturn FWD dirt track race car hinsonracing S-Series Mods 8 05-11-2015 09:44 PM
Building a 2002 SC2 for dirt track racing, security problems with no ignition lock wildmandan S-Series Tech 3 12-25-2011 03:25 PM
Setup for a dirt track Saturn 5ton S-Series Tech 8 12-20-2011 12:19 AM
Saturn in oval-track race! Twin_Cam S-Series Mods 9 06-28-2004 01:56 PM
Dirt oval Saturns QuickSilverSC2 Mods and Performance 8 03-20-2003 10:14 PM
