Old 07-16-2017, 08:56 PM   #1
Hoodedkitty
Hoodedkitty is on a distinguished road
Default Engine light on car smoking then fine again
My engine light came on the other day and the car was smoking under the hood and blowing blue smoke out the back as I drove and I had choppy acceleration too. Then I put in some oil and some stuff that said it fixed leaks and two days later the engine light went off and the car runs normal again. Any ideas what caused this so I can get it fixed better or should I just keep running it?
Add to Hoodedkitty's Reputation
Rate the quality of this post and help Hoodedkitty reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hoodedkitty is offline   Reply With Quote
Old 07-16-2017, 11:03 PM   #2
billr
Default Re: Engine light on car smoking then fine again
How much oil did you have to add to get it up to the "full" mark on the dip-stick? Why do you think you have an engine-oil leak? Does it smoke now, or has that gone away?
Add to billr's Reputation
Old 07-17-2017, 08:25 PM   #3
Hoodedkitty
I added a quart plus the stop leak stuff that was like half a quart. It said to run the engine for 15 minutes and while it was running there was a steady drip of oil falling on the ground. When I got to work it dripped a bit while I was inside but when I got home it didn't leak anything. It doesn't smoke anymore. This all started after I took it on the highway once I hit like 50 the engine light started flashing
Old 07-17-2017, 08:41 PM   #4
guyg
guyg will become famous soon enough
1997 SW2
A flashing engine light is usually a misfire, have you serviced the plugs and wires?
Add to guyg's Reputation
Rate the quality of this post and help guyg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guyg is offline   Reply With Quote
engine smoking tmatkins S-Series Tech 7 06-05-2014 11:26 AM
smoking engine...help johnnasi S-Series General 8 04-07-2013 10:26 AM
Check Engine Light, Transmission codes, but shifts fine! caryard S-Series General 4 09-02-2007 02:22 AM
Cold engine fine, warm engine misses ?? Scyan S-Series Tech 9 11-04-2002 11:08 PM
Smoking Engine NovaScotiaSL1 S-Series Tech 5 12-02-2000 05:51 PM
