Old 07-16-2017, 08:45 PM   #1
Rob ion
Rob ion has a spectacular aura aboutRob ion has a spectacular aura aboutRob ion has a spectacular aura about
2003 ION-2 Sedan
Default Key stuck
The key was stuck in the ignition until I disconnected the battery. That is the shift interlock switch right? If so where is it.
Add to Rob ion's Reputation
Rate the quality of this post and help Rob ion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rob ion is offline   Reply With Quote
Old 07-18-2017, 03:12 PM   #2
Rob ion
2003 ION-2 Sedan
Default Re: Key stuck
Nobody? Really?
Old 07-18-2017, 07:59 PM   #3
ryan_ion
ryan_ion has a spectacular aura aboutryan_ion has a spectacular aura about
2007 ION-2 Sedan
If you have not done the recalls yet, that is step one.
2007 Saturn Ion 2- Totaled @ 120K miles and dearly missed.
...control arm bushings(x3), wheel bearings, end links, axle seal, intermediate shaft... but still the original battery!
Add to ryan_ion's Reputation
Rate the quality of this post and help ryan_ion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ryan_ion is offline   Reply With Quote
Old 07-19-2017, 12:38 PM   #4
Citation84
Citation84 has a spectacular aura aboutCitation84 has a spectacular aura about
Citation84's Avatar
2005 ION-1 Sedan
Rob: if your car is an automatic there is a small square panel under the steering wheel. Take that off and feel for a little button inside. That button will release the key.
You can do that until you have the recall done. It may still happen after replacing the final recall switch [as mine did ] and the fix was [and I received a letter from GM regarding the possibility of this] BTSI replacement. Also covered by GM.
After 10 years it's finally fixed and if the BTSI goes again, I'm going to leave the little panel off and diddle the button till the day the car dies.
The BTSI on mine [in the console, see a thread here in the ION Tech forum] was replaced three times, the switch, four, over those 10 years.
I applied for the reimbursement after the 3rd one I had to pay for myself and got it.
Add to Citation84's Reputation
Rate the quality of this post and help Citation84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Citation84 is offline   Reply With Quote
Stuck Key lancer54 S-Series General 8 12-09-2013 04:24 PM
Stuck in First Usagi S-Series Tech 25 05-27-2013 12:49 AM
stuck cd watts8888 2008 Vue 7 07-23-2011 04:42 PM
oil cap stuck 97sl2DOHCaut1.9 S-Series Tech 3 09-26-2009 08:31 AM
Stuck in snow....now stuck with no go. Transmission issue raceddaily S-Series Tech 19 03-22-2008 05:33 PM
