Old 11-16-2017, 02:40 AM   #1
canada_rokzz
canada_rokzz has a spectacular aura aboutcanada_rokzz has a spectacular aura aboutcanada_rokzz has a spectacular aura about
2008 Astra XR
Default Immobilizer Key Reading Coil
I accidentally broke mine today working on my command start. Ugh. How pooched am I? Is this part paired to the key?
File Type: jpg DE5529E3-0611-4B7B-9D20-3339E9C4CC1F.jpg (116.8 KB, 16 views)
2008 Saturn Astra XR 3 Door
Add to canada_rokzz's Reputation
Rate the quality of this post and help canada_rokzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
canada_rokzz is offline   Reply With Quote
Old 11-17-2017, 05:27 AM   #2
Default Re: Immobilizer Key Reading Coil
Are you able to startup and drive or not? Previous GM security (Passlock), when faulty would disable itself and allow starting and driving without theft protection. The security light remains ON all the time to indicate Passlock failed and theft protection isn't available. Passkey, if under certain conditions may allow drivers to use their vehicle but have no theft protection. Better to have zero theft protection that allows vehicle use than having security enabled and active, preventing vehicle use until repaired. Which situation are you in?
If you have Passkey (rfid chip in the key), the rfid is the same as EZ-PASS where a transponder (xmitter) excites a coil to generate a discrete (coded) signal for the receiver in the xponder to detect, send the signal to the bcm for security checking. The damaged part is not matched to the key. Every rfid chipped key is discretely coded differently from the other. Family pets are using the same rfid capsule inserted under the skin for identification with a hand held transponder displaying the ID number. Replace the damaged part and you'll probably restore security function.
Old 11-19-2017, 07:15 PM   #3
canada_rokzz
2008 Astra XR
Replacing the part was all it needed.
Renting: Input nut immobilizer tool cgheming S-Series Tech 5 01-27-2010 10:26 AM
Best reading yet on DIC logbite Outlook General 5 10-22-2007 08:31 PM
Does the 2002 SC2 have a built in immobilizer? bigtoque S-Series General 6 08-24-2006 06:36 PM
Immobilizer Q Esca Ion General 16 04-08-2004 08:48 PM
Interesing Compression Reading... So... carbon can REALLY affect your reading huh? amazinghl S-Series Tech 21 11-20-2003 11:46 PM
