Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 07-11-2017, 12:50 PM   #1
noodles
noodles is on a distinguished road
Default 2004 Redline AC not working, needs computer
I have had the compressor replaced on my 2004 Redline 3.5L, the system recharged but the compressor will not come on. The shop, who I trust, performed testing and diagnosed it as a bad computer. My question is which computer controls the AC system? If I buy a used computer will I have to have it reflashed? I have learned so much from this forum, thanks for your help!
Add to noodles's Reputation
Rate the quality of this post and help noodles reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
noodles is offline   Reply With Quote
Old 07-11-2017, 01:14 PM   #2
Default Re: 2004 Redline AC not working, needs computer
Sophistication in electronics also means communications between computers. Ecm, bcm, tcm, abs/tc/esc, OnStar, radio, hvac, etc., are all communicating to each other or to the bcm as the bcm provides the gateway for OBD II diagnostics. You should ask the repair shop that did the ac work since they're supposed to know this (unless they don't then it become a problem in more ways than one). HINT: hvac control panel if yours uses auto climate controls. The hvac control panel communicates to the ecm or pcm that ultimately turns on the compressor. If your repair shop doesn't know this................ BTW, I'm just another diyer with my own service manuals and access to other manuals to know this.
Old 07-12-2017, 10:17 AM   #3
noodles
Thanks for the response. The computer is not sending a signal for the compressor to engage. I do not have automatic climate control, it is manual. He performed a pretty comprehensive diagnostics & told me the compressor is not getting the signal to engage from the computer. The previous owner did a real hack job when installing an aftermarket radio. I'm wondering if they may have cut a wire under the dash causing my issue as all the other components are functioning properly. Does anyone have a wiring diagram for the AC control system? I'd like to try & trace the wiring issue myself before committing to a new computer.
Old 07-12-2017, 11:35 AM   #4
Does this shop use service manuals? Even with manual HVAC controls, the HVAC control panel is electronic and sends an AC request signal to the body control module, forwarding this request to the ECM or PCM. The ECM/PCM sends a command signal to the ac relay that powers up the compressor. You have three modules to choose from; HVAC control panel, bcm or ecm. I use service manuals when discussing diagnosing and troubleshooting.
Old 07-12-2017, 03:10 PM   #5
Mustangman03
Mustangman03 has a spectacular aura aboutMustangman03 has a spectacular aura aboutMustangman03 has a spectacular aura about
2002 VUE 3.0L
Just to add to fdryer's post it also has to read the right amount freon pressure in high line and low line.. if it has a clog or to much pressure or not enough pressure it will not turn on.
Add to Mustangman03's Reputation
Rate the quality of this post and help Mustangman03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mustangman03 is offline   Reply With Quote
Old 07-13-2017, 03:37 PM   #6
noodles
All components have been checked by a reputable shop and are fully functional, the system is fully charged. The final diagnosis is that the compressor is not getting the signal engage from the computer. The previous owner hacked up the wiring under the dash installing a stereo & I'm wondering what other damage they may have done. I want to try & trace the wiring from the BCM to the ECM before I spend more money at the shop. I am in dire need of a wiring diagram for the wiring harness from the BCM to the ECM and possibly the ECM to the compressor. Everything else controlled by the BCM is fully functional so I am thinking the previous owner may have cut a wrong wire. I have been searching the web for a wiring diagram but have not had any luck. I truly appreciate the assistance that is being offered.
Old 07-13-2017, 05:19 PM   #7
jco35
jco35 is on a distinguished road
2005 VUE Red Line
PM far2grumpy. He maybe able to help you with the wiring diagram you're looking for.
Add to jco35's Reputation
Rate the quality of this post and help jco35 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jco35 is offline   Reply With Quote
Old 07-16-2017, 11:56 AM   #8
far2grumpy
far2grumpy's Avatar
I didn't receive request but will post a few thoughts and items in event OP still has a problem.
I assume A/C shop pulled the clutch relay and installed jumper between pins 30 and 87 to verify basic A/C system operated normally.
Regarding pressure issues - low or high pressures should set a code - check engine light will not be lighted but codes such as P0530 (sensor fail), P0532 (low pressure) or P0533 (high pressure) are generally stored.
First thumbnail is marked up diagram of A/C control circuit and second depicts the HVAC control scheme but MOST IMPORTANTLY has the TXV evaporator temperature monitoring circuit.
Last thumbnail is for blower circuit and problems there-in can result in BCM not sending compressor run data to PCM. See text on diagram for details.
Use care if you decide to substitute another HVAC controller ... wiring diagrams indicate differences between 02-04 Vues, 05 Vue and 06-07 Vues.
ALERT ... I just realized I marked up incorrect diagram ... I used 2005 Vue which indicates Circuit 60 yellow wire is routed between C2-4 and C1-11 and I should have used 2004 Vue diagram which has circuit 60 wire between C2-4 and C1-20. My bad.
Old 07-17-2017, 05:36 PM   #9
noodles
Thank you Far2grumpy!, I have not had a chance to work on my vehicle since last week between work & family obligations.I will ask your question in regards to jumping the relay.This shop has done right by me for quite a few years, but you never know if he missed something. I appreciate your guidance & advice. I'm sure that I will be back with more questions. Have a great evening, off to trace some wiring.
2004 ion redline in NY geo1nineteen Classifieds 0 10-30-2014 07:06 AM
2004/07 Redline vs 2008/09 Vue Redline redhawk110 Vue Red Line 3 07-31-2014 12:25 PM
Cant Read computer on a 2004 Saturn Vue rvisualdesign Vue Tech 12 03-22-2013 02:31 PM
2004 Vue redline dal75 Vue Red Line 3 05-27-2006 07:48 PM
2004 ION Redline NEW pt. 2 dschrader Classifieds 2 10-18-2005 11:42 AM
