Old 06-03-2017, 03:08 AM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Roll Eyes 2004 automatic 3.5 awd
2004 Saturn automatic 3.5L AWD 177K
Vue is showing red low oil pressure light on dash....
Oil is not low ....it has full oil...so we can think of oil pressure sensor could be bad but here is what happens...
In idle it does show low oil pressure light but engine does not shut off but when driving for about 10 minutes light is still there but engine shut off ...
If Oil pressure sensor is bad ...won't it shut off engine in idle as well?
Why it shuts off only while driving for about 10 minutes..
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 06-03-2017, 08:52 AM   #2
billysvue
Default Re: 2004 automatic 3.5 awd
"Shuts off" means what?
- no power whatsoever, all electrical goes dead( lights radio, etc...) and you coast to a stop? Or what exactly?
Maintenance history/odo is???????
OIl is how old? Synthetic?
C.E.L. code?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 06-03-2017, 01:12 PM   #3
atikovi
The oil light is for pressure not level. I wouldn't drive it 10 seconds let alone 10 minutes with that light on.
Add to atikovi's Reputation
Old 06-03-2017, 02:20 PM   #4
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
But oil pressure sensor can be bad which is why it could show false indication on dash?
Old 06-03-2017, 02:34 PM   #5
atikovi
Either test the pressure or put in a new sensor before driving unless you feel lucky.
Old 06-03-2017, 02:50 PM   #6
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
How do I check oil pressure ...I have obd2 adapter but android app 'torque' does not show oil pressure check option
Old 06-03-2017, 03:36 PM   #7
atikovi
You need to remove the sensor and connect a test gauge like http://www.tooltopia.com/otc-tools-5..._95RoCIv3w_wcB If the sensor is pretty cheap, you can just replace it instead.
Old 06-04-2017, 04:05 AM   #8
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Thanks,
Remove oil pressure sensor and put test gauge there ...or I have make a T with an adapter? also there are two right next to each other ...one is sensor and other is sender ...which one I should remove and install the test gauge?
Old 06-04-2017, 05:36 AM   #9
atikovi
You didn't mention it also has a gauge. If the gauge reads normal but the light is on, it's almost always a bad sensor for the light. Read up at http://www.saturnfans.com/forums/sho...d.php?t=229989
Old 06-04-2017, 01:19 PM   #10
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Car does not have gauge ...I bought mechanical gauge ..not sure where to hook it up? there are two ports which are occupied...one has green connector other has black...which port I should hook my oil pressure tester gauge to?
in other words one sensor is for light and other is for actual oil pressure ?
I am confused...
on Rockauto when I found AIRTEX/WELLS 1S7668 {#12582260, PS592} Info
Oil Pressure Switch; with Gauge and other says oil flow control switch with gauge AIRTEX/WELLS 1S7596 {#12582261, PS593} Info
Oil Flow Control Switch; with Gauge
so one says oil flow control switch which is green connector ...should I remove that and install my mechanical gauge to check pressure or I should remove the other one?
2004 Vue Automatic Loc issue oxfordbrent Vue Tech 3 04-14-2016 01:22 PM
2004 Ion Coupes with a 5 speed automatic? FnKVn Ion General 19 08-29-2013 09:31 PM
What mileage should I change the automatic trans fluid 2004 ion2 SC Saturn Owner Ion General 9 01-14-2010 02:09 PM
2004 Ion 2 or 2004 Vue? (or taking advice from complete strangers) kennywhy General Saturn Discussion 11 12-28-2004 12:30 PM
2004 Ion 5 speed Automatic Transmission fredrick Ion General 2 10-22-2004 11:13 AM
