Old 05-19-2017, 11:34 AM   #1
78boarder
78boarder is on a distinguished road
2008 VUE 2.4L
Default 2008 XE Coolant Leak
Hi,
My 2008 XE has a coolant leak. It's leaking from the rear of the engine. At first I thought it was transmission fluid (both are red color) because it was dripping from the transmission pan, but I'm losing coolant. Plus further investigation looks like the drip is coming from what I think is the water transfer tube. Without removing parts (like the exhaust heat shield), I can't see any further up. The picture isn't great, but it shows the drip (this is looking up from the ground). I tried to check the hoses and reservoir in that area, and I don't believe any of those are leaking because they felt dry.
Are the seals between the thermostat housing and transfer tube a common leak point? Is there anything else in this area that could be leaking or is the transfer tube/thermostat housing the likely culprit? Based on the service manual, this doesn't seem like that hard of a job. Is that a correct assessment? What else should I replace while I'm in there? The thermostat and gasket/o-rings are a no brainer. Anything else?
Tim
Methuen, MA
2008 Saturn Vue XE, 150,000 miles
Add to 78boarder's Reputation
Rate the quality of this post and help 78boarder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
78boarder is offline   Reply With Quote
Oil Leak, Coolant Leak, Alternator, Compressor Bobcat124_23456 L-Series Tech 4 03-25-2013 09:13 PM
2008 Vue XR 3.6 v6 oil leak front of engine luciano Vue Tech 15 09-16-2012 02:35 PM
2008 Saturn XE coolant leak? tweak Outlook General 3 07-02-2012 01:01 AM
Washer fluid leak in a 2008 VUE dulino 2008 Vue 2 12-28-2009 08:59 AM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 11:56 AM
