Old 05-19-2017, 08:33 AM   #1
saturnmommy
saturnmommy has a spectacular aura aboutsaturnmommy has a spectacular aura aboutsaturnmommy has a spectacular aura about
1997 SL1
Default motor mounts and transmission mounts help
I have a 1997 saturn sl1, 1.9L SOHC. A good amount of noise and vibration happening so we are going to replace all 4 of the mounts. Did the upper motor mount a couple years ago but did not "reset" the bottom dogbone so I don't know if that has something to do with the return of the vibrations or not. Anyway, that is the only mount ever replaced on my car so its probably time to do them all.
Does anyone know the proper torque for each of the mounts?
Upper Motor, Lower dogbone, Upper Transmission and Lower dogbone????
Is this a hard job with all the other mounts, because I cannot find any videos about the 97 Saturn SL1 to watch. I found plenty on other models but none on mine.
Is there any difference in the two dogbones by the way since they are not marked or does it not matter which goes where??
Add to saturnmommy's Reputation
Rate the quality of this post and help saturnmommy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnmommy is offline   Reply With Quote
Old 05-19-2017, 08:48 AM   #2
Default Re: motor mounts and transmission mounts help
99% same procedure for all mounts on all '92-'02 S-Series, the 1% being the lower transmission mount on automatic's being an actual challenge, sometimes requiring dropping the cradle on that side to get it in or trimming the length of the stud (the 5spd's being a proper transmission leave enough room to get the mount in fairly easy).
Dog bones are identical, doesn't matter which goes where.
IMO you can cheap out on the dog bones and probably the transmission mount but the top engine mount really needs to be an actual OEM mount.
The top mount studs: ~19ft/lbs, the nuts 40ft/lbs (all 5)
10mm trans mount bolts: 23ft/lbs
15mm trans mount bolt: 41ft/lbs
dog bones 40ft/lbs
Old 05-19-2017, 09:01 AM   #3
RobertGary1
Top mount and to a lesser degree the bottom reduce vibration when idling. The dog bone mounts will cause clunking noises when you leave a stop when they go bad as the engine torques.
-Robert
Old 05-19-2017, 09:20 AM   #4
saturnmommy
1997 SL1
dog bones 40ft/lbs
Thank you. We did cheap out on the parts this time around but not sure if the top one is in need of change anyway might not mess with that one. The others are still original parts and its nearly 24 years old now so I don't know how long they usually last but I will take 24 years.
Old 05-19-2017, 09:27 AM   #5
saturnmommy
1997 SL1
-Robert
Thank you. The only mount ever changed on the car was the upper, so I think after nearly 24 years of having my car it is probably time to change the other three out. She has her fair share of clunks and rattles and more so its hard to tell sometimes what is doing what with her.
Old 05-19-2017, 12:17 PM   #6
RobertGary1
Watch out for the auto parts store life time warranty mounts. You'll be replacing them for the rest of your life.
-Robert
Old 05-19-2017, 11:54 PM   #7
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
-Robert
Ha!! I believe that! Avoid AZ unless you really know what you're buying. Almost everything they sell seems low quality IMO. But all seem to come with lifetime warranties ... whoopty doo
I go OEM for engine and trans mounts. But I've had good success with aftermarket DEA torque strut (dogbone) mounts.
'97 SL1, 136K, Auto, Mint Green (SOLD 146K)
'99 SL2, 126K, Auto, Silver (SOLD 149K)
'97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K)
'02 SL2, 149K, Auto, Light Gray/Silver
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bachands is offline   Reply With Quote
Old 05-20-2017, 08:05 AM   #8
jmilroy
jmilroy is on a distinguished road
jmilroy's Avatar
For those who might not realize...
"Lifetime Warranty" does NOT mean "if it ever breaks or wears out, we'll replace it." If you buy "Lifetime" brake pads, water pumps, alternators, etc., and they wear out in a couple of years, there is no obligation of the FLAPS to replace the item, unless you can prove it was MANUFACTURED with a flaw.
Just to clarify what the lawyer-speak means...this is taken directly from a major chain auto parts website:
"A Limited Lifetime Warranty is a warranty against defect in materials or workmanship under normal use and service after proper installation..."
In other words, "if me made it wrong, you've got a case, but if it wore out in use, you get nothing."
[Of course, you might find an individual part or individual store with a full wearout replacement warranty...I just wanted to clarify the dubious "lifetime warranty" frequently encountered.]
Cheers,
Add to jmilroy's Reputation
Rate the quality of this post and help jmilroy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jmilroy is offline   Reply With Quote
Old 05-20-2017, 03:52 PM   #9
RobertGary1
Autozone doesn't ask question they just exchange. But it's your labor time. I just returned an 8 year old radiator and exchanged for new.
-Robert
Old 05-20-2017, 09:55 PM   #10
jambra1
jambra1 is a jewel in the roughjambra1 is a jewel in the roughjambra1 is a jewel in the roughjambra1 is a jewel in the rough
Cheers,
I've been shopping at AutoZone for well over 30 years and have never had a problem with a lifetime warranty exchange whether a radiator, TPS, IACV, brake pads or any other item. They look up my account for the original purchase and it's "no questions asked." With a pair of 99s, including one with 413K miles, I've definitely gotten my money's worth. On a few items where I use a Duralast product, they may tend to wear out a bit sooner than the OEM but, as mentioned, it's just my labor time on the swap. (For what it's worth, I use the OEM on those parts where it's essential.)
Current
1999 SC2 - 426,000 miles
1999 SL2 - 197,000 miles
Previous
1996 SC2 and 1999 SL2
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline   Reply With Quote
Old 05-21-2017, 12:07 AM   #11
Jonasan308
Jonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of light
Jonasan308's Avatar
1999 SC1
24 years old? If its a 97, than its been a bit over 19 years since the start of 1997... 1997 is my birth year. Technically it would be 20 years old because of that thing about making next year classed cars.
1999 Saturn SL1-129k at purchase(may 2016)-139k when wrecked(September 2016)
1999 Saturn SC1(CURSED)-156K at purchase(october 2016)-181k currently (apr 2018)
Dodging potholes should be a sport
Add to Jonasan308's Reputation
Rate the quality of this post and help Jonasan308 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonasan308 is offline   Reply With Quote
Old 05-21-2017, 01:04 PM   #12
saturnmommy
1997 SL1
No offence but I don't need the math lesson. When you are as stressed out as I am then you will understand how people can simply make a math mistake. It really does not amount to jack either way as my cars age don't matter, just the issues she is having. Thanks though for your lack of assistance here. I would prefer help from people and not a math correction though. geeze!
Old 05-21-2017, 01:40 PM   #13
Jonasan308
Jonasan308's Avatar
1999 SC1
Wasnt really trying to make you look stupid or anything, just wanted to point it. Youre right though, it seems like you are quite stressed out.
Old 05-22-2017, 07:17 AM   #14
saturnmommy
1997 SL1
I am extremely stressed out however you in no way made me look stupid. I don't allow anyone to attempt to make me look any different from the way I am. You were born in 1997 you said..well in 1997 I was already on this earth for 23 years...ahh nearly as long as my car is old!!! My motor mounts are all in and everything is good with that issue. Now move on to even more issues to fix with my baby.
Aftermarket trans mounts and torque mounts terminal89 S-Series Tech 5 07-30-2016 08:55 PM
Ordering Struts and mounts from Tire rack - $330 for all 4 + mounts m4gician Vue General 6 02-05-2010 02:49 PM
motor/transmission mounts & reverese problems bdobraj S-Series General 6 05-12-2009 10:10 PM
WTT: SPS Motor Mounts for Stock Motor Mounts soccer69er Classifieds 1 10-28-2004 06:13 PM
Where to get new motor mounts? SL2Fan Mods and Performance 1 08-07-2001 07:07 PM
