#1 | ||||
![]() ![]() ![]() Join Date: Nov 2006
![]() Hey folks, it's been awhile.
A couple months ago, I started noticing some noise (squealing/clanking) coming from the passenger side of the Vue, usually when I was near a wall or something that reflected the noise. Thought maybe a brake caliper was loose. Took it in and they said it needed rear drums and shoes. The work was done, and within just a few miles, the new shoes pretty much disintegrated. They were replaced at no charge, along with the wheel cylinders, both of which appeared to be missing a small clip that keeps the shoe in place/stable. After this was done, there was a new sound, like TAP TAP TAP TAP in the rear driver's side when braking. I took it back and they replaced both the drums and the shoes under warranty. Now, it still goes tap tap tap tap just not as loud. Any idea what I'm dealing with here? This is a pretty good shop, well regarded in the area. They're stumped other than "it may work itself out over time". Also, how long should brake shoes/pads last on these things? I had the front brakes done last September (different shop) and the new shop said they were at 30% now. 10K miles max. Seems ridiculous! ... 2007 VUE AWD V6 3.5L
#2 | ||||
![]() ![]() ![]() Join Date: Aug 2012
![]() New drums need to be turned- twice- once to rough out the grind and second to hone it true( very light cut).
It's an art. I had the same issue with new drums, and after a wrench monkey turned the drums to attempt a fix. Went to my trusted alignment shop( MIlo JOhnson Auto, Escondido,CA). They turned them properly and the clicking /tapping was gone. If the rears are dong their fair share/adjusted properly, the wear on the front pads should take you 70K miles or more. ... '05 ,2.2L, FWD,5-speed stick with transaxle death rattle is history,,, '17 Suby Forester 245216 mi. VUe is off to the dealer auction I'm a secondhand vegetarian. Cows eat grass, I eat cows.
#3 | ||||
![]() Great info thank you. It would seem, however, that the drum manufacturer should do the steps. Why would they expect a shop that may not have a lathe to turn anything would do this?
Based on this I expect over time the tapping will go away on its own. ... 2007 VUE AWD V6 3.5L
#4 | |||||
![]() Quote:
THe rear brakes will not adjust themselves.... ... '05 ,2.2L, FWD,5-speed stick with transaxle death rattle is history,,, '17 Suby Forester 245216 mi. VUe is off to the dealer auction I'm a secondhand vegetarian. Cows eat grass, I eat cows.
1998 Saturn sw2 rear brake emergency brake lever | Dave27889 | General Saturn Discussion | 4 | 06-10-2016 11:01 PM |
Rear Brake Issue | proveniebam | S-Series Tech | 4 | 03-26-2013 05:35 PM |
Parking brake/rear caliper issue | derf | S-Series Tech | 17 | 04-02-2009 10:51 PM |
brake issue | storm_amoure | S-Series Tech | 14 | 12-29-2007 03:18 PM |
Rear Brake noise after brake job | kim_lombard | S-Series General | 5 | 04-22-2007 10:40 PM |
