Old 05-18-2017, 09:55 PM   #1
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
Default Help with Exhaust Manifold to Down Pipe Studs and Nuts
I am working on the exhaust for my '97 SL2. When I removed the downpipe I noticed there is a missing stud (replaced with a standard bolt) and the nuts are not original. The nuts don't have the rounded bottoms, so there were washers underneath them. I don't like the separate washers. It's easier to install a proper nut without having to hold the washer in place during installation.
So what are my options at this point? Are the exhaust manifold studs (at the cylinder head) the same? Could I just go to the salvage yard and get a stud and three nuts at the exhaust manifold?
i found the P/Ns for the studs and nuts from another thread. But for one stud and a bag of nuts, the total comes out to more than $20 after shipping. That seems like too much for such a trivial thing.
What's a good option if I just went to the hardware store? Menards has some automotive grade hardware. Would they have what I need for this?
'97 SL1, 136K, Auto, Mint Green (SOLD 146K)
'99 SL2, 126K, Auto, Silver (SOLD 149K)
'97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K)
'02 SL2, 149K, Auto, Light Gray/Silver
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bachands is offline   Reply With Quote
Old 05-18-2017, 10:18 PM   #2
bachands
Default Re: Help with Exhaust Manifold to Down Pipe Studs and Nuts
I found the following kit on Ebay: Manifold Hardware Kit
This should work right? I could replace all 5 manifold studs and the 3 studs to the downpipe, and still have two leftover.
Old 05-18-2017, 10:33 PM   #3
Saturn Night
You can use intake manifold studs and nuts, the way I did on my 1992 manifold swap. The intake studs are the exact same part # as the exhaust, which is discontinued by GM.
The intake nuts are slightly different, than the exhaust nuts. The exhaust nuts were designed to torque and lock onto the studs. Use of the intake nuts will require you to re-torque them after 50 miles of driving, or the first 10 hours of operation.
Once they are re-torqued, you should be fine. The intake nuts have an integral washer, so no problems with alignment.
The intake side doesn't get near as warm as the exhaust, hence why you will need to re-torque them.
Some yards will allow you to pull the studs, yourself, and not charge you. Just make sure they come from a junk engine, as they will not let you pull the intake manifold off a good engine.
Old 05-19-2017, 12:08 PM   #4
bachands
So I was able to find the same Dorman kit at Oreilly Auto Parts for even less than Ebay. It seems that the threads fit the exhaust manifold on both ends. The only difference is that the length of the threads on the end that goes into the cylinder head or manifold flange is a bit longer. Not much longer...I'd say about 1/8 of an inch. Also the ends are male hex-head rather than Torx-head.
I doubt the quality of the hardware is as good as that of the OEM, but it seems to be a suitable replacement.
Old 05-26-2017, 04:08 PM   #5
TomM96
I think those are about the most stressed fasteners on the car.
Aftermarket will probably work , but will probably Not allow more than one fastening-- so if there's a requirement to re-do the attachment , yopu may be in same situation then.
The catcon bolts get more heat & saltspray , but they have much less stress.
Add to TomM96's Reputation
Old 05-26-2017, 10:10 PM   #6
bachands
The key is to use stainless steel hardware when possible. I did this when I installed a new cat con outlet flange to a new rear pipe. Months later I had to remove it to replace the oil pan. It came off with little difficulty
I also like to put a light coating of high temp grease on the exposed threads. This helps to inhibit rust and corrosion.
As for the Dorman exhaust manifold studs I used, they are not SS. However, to help with removal (if it is ever needed again), I coated the threads that go into the head with anti-seize. Then I put some high temp grease on the exposed threads. It turned out pretty good. However, I really had to clean the female threads in the head before installing the new studs. I used a tap, several Q-tips sprayed with brake cleaner, and compressed air.
Old 05-27-2017, 08:00 AM   #7
You can replace intake and exhaust studs with stainless steel Allen head set screws. They come in longe enough sizes that will replace the OEM. McMaster - Carr stocks them. Use a plain blunt end set screw. Be sure to use a nickle based antiseize on them as well.
Old 05-15-2018, 01:49 PM   #8
BConrad74
BConrad74 is on a distinguished road
2002 L-Series 2.2L Sedan
I am missing a stud where the manifold and catcon meet. There should be three and theres one missing somehow. I bought this car used so they must have left one out while replacing the engine. The good part is it looks like I can just put a bolt in there to hold it together. My question is, are the bolts the same thread as the bolts that hold the manifold to the head? Or what bolt should I be looking for?
I believe this is where I'm having a small leak thats throwing the p0420 code. So I'm hoping that by throwing a bolt in there to tighten it up will solve that issue.
Thank you for any help on this.
Add to BConrad74's Reputation
Rate the quality of this post and help BConrad74 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BConrad74 is offline   Reply With Quote
Old 05-28-2018, 11:25 PM   #9
bachands
Yeah. I believe there the same. I think I used a stud from the same package (the Dorman studs referenced above) on the exhaust manifold-to-downpipe connection. I couldn't get the other two out...too rusted.
Old 05-29-2018, 06:37 AM   #10
The exhaust (upstream from cat-con), intake & starter all use the same thread pitch just different lengths/styles. The intake use's ~3in studs, exhaust use's ~1.5in studs and the starter use's bolts that smart people swap for studs (intake studs are easiest to find in a JY). The nuts are all the flange style and if you want to take it apart in the future would benefit from high-temp copper anti-seize on the exhaust.
Old 05-29-2018, 07:57 AM   #11
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
I've had the replacement studs/nuts kit from Oreilly's for a year and a half no issues, and the finish hasn't oxidized horribly. Deffinetly coat the the exposed surfaces with grease to keep them from fusing and looking good.
We need a thread dedicated to Oldnuc's high quality alternative options that work. I digg the idea of stainless studs o .o
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
03 L200 Exhaust Manifold-to-Head Studs/Nuts cmac212 L-Series Tech 4 03-09-2014 07:17 PM
intake manifold studs+nuts rv93 S-Series Tech 0 08-25-2013 10:05 PM
Exhaust studs/nuts torque? myolbug S-Series Tech 1 10-18-2012 03:30 PM
Replacement exhaust manifold studs/nuts??? emr131 S-Series Tech 6 06-30-2010 09:11 PM
93' SC1 Catalytic to Exhaust pipe fasteners:Studs or nuts and bolts? gbriceno S-Series Tech 8 04-10-2010 11:34 AM
