Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 05-16-2017, 04:26 PM   #1
Hank Rearden
Hank Rearden is on a distinguished road
2005 VUE Red Line
Dizzy 2005 Saturn Vue Redline engine removal
Hello everyone.
I need some help. It looks like I might have an engine block crack. 3.5L If so it is broken behind the front motor mount or torque mount. It just started to flow like a garden hose after I parked it one day. I mean like the kitchen faucet set in a low smooth flow.
Anyway. The dealer said it was cracked. I can't actually see the crack. Because it appears to flow from behind the mount. I'm going to assume that's a correct diagnosis. Although I really need to see it since the dealers have been wrong before in my experience.
Yes I used a mirror and lights. I can't actually see a crack. So can anyone tell me if this might be something simple or common.
If I need to pull the motor is it best to drop the whole thing out of the bottom.
Any reference or YouTube vids would be great. I couldn't find them.
Add to Hank Rearden's Reputation
Rate the quality of this post and help Hank Rearden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hank Rearden is offline   Reply With Quote
Old 05-17-2017, 12:27 AM   #2
bern
2004 ION-2 Sedan
Default Re: 2005 Saturn Vue Redline engine removal
Even thou I had not have had to pull this 3.5L. I known the engine and trans is in there tight. With the opening on the top being smaller you'll likely need to remove at least 1 catalytic convertor. I think you'll better off dropping it out the bottom.
Do you have access to shop with hoist?
Add to bern's Reputation
Old 05-17-2017, 07:19 AM   #3
atikovi
First thing to do is find the leak. Maybe stick a garden hose into the coolant bottle and crawl underneath. Do these engines have casting plugs that may have gotten loose? If you find a crack, can you use an epoxy patch? There are chemical block sealers you add to your radiator as well.
Add to atikovi's Reputation
Check engine light 2005 redline Naunakaye Vue Red Line 1 05-05-2014 01:00 PM
Humming noise from 2005 Saturn Vue Redline Joshua_D Vue Red Line 5 12-23-2013 07:58 PM
Humming noise from 2005 Saturn Vue Redline Joshua_D Vue Tech 3 08-18-2013 06:31 AM
2005 3.5L Engine Removal cliff_m_b Vue Red Line 10 10-21-2011 11:29 AM
Engine removal - 2005 Vue msgrape Vue Tech 12 06-30-2007 08:59 AM
