Old 04-20-2017, 08:54 PM   #1
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
Default Today's Mystery Connector
You'll love this.
For years I have seen this connector, tyrapped near the radiator on the passenger side of my SC. I never really looked too close at it, everything works fine on the car, no mystery codes, etc. Without giving it much thought, I assumed it was an unused connector for fog lamps or something.
Today I was cleaning my EGR, general spring maintenance and decided to look closer. It only has 1 green wire in it, so obviously cannot be for foglamps, plus looking closer at the connector it looks more like something for a sensor of some sort. There is nothing nearby that looks like it is missing a connection. The location and clip mount indicates the connection must in the vicinity but nothing is obviously unplugged. Like I said, everything works fine, I do not know if it has been tyrapped there from the factory (doubt it) or whether the PO did it back in the day.
Any ideas?
Thanks
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Add to Ricketts's Reputation
Rate the quality of this post and help Ricketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ricketts is offline   Reply With Quote
Old 04-20-2017, 09:11 PM   #2
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
Default Re: Today's Mystery Connector
Without a better look at it, I'd guess it goes to the AC compressor if you had one, but Gen 3....isn't there some kind of air valve on the Gen 3 right around that right front side of the SOHC engine?
Old 04-20-2017, 09:28 PM   #3
Ricketts
2000 SC1
Dunno about an air valve, but you could be right about an AC connector, it would make sense. Since I don't have AC I just would have thought it would be wrapped out of the way better if it was a redundant connector from the factory.
Does anyone have a wiring diagram that shows the color code for an AC connector?
Old 04-20-2017, 10:09 PM   #4
Your car uses a single dark green power wire to the a/c compressor. One way to verify this connector as the power wire would be measuring it for 12 volts when; locating the a/c relay and removing it (if one exists), familiarizing yourself to relay pinouts, inserting a small wire jumper across relay socket terminals 30 and 87 - sending fused a/c power to the compressor. A fuse and relay would have to be in place in the engine fuse box. Another way would be a continuity test between this connector and either terminal 30 or 87 (the a/c fuse should be removed to prevent sending 12v into a meter set for resistance/continuity testing.
Old 04-20-2017, 10:48 PM   #5
Ricketts
2000 SC1
I found a wiring diagram from you fdryer on another thread - it does look like the AC compressor connector. I'll verify continuity with terminals 30 and 87 this weekend, but I think this may be mystery solved
Thanks
Old 04-21-2017, 09:55 AM   #6
dummo
dummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nice
dummo's Avatar
1997 SW2
Hey, Can I take my AC Compressor off from my SW2 without much trouble or issues later on in life?
or am I dreaming?
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 04-21-2017, 10:25 AM   #7
If you want to remove dead weight, yes. You'll have to find a non a/c drive belt.
Identify this mystery connector... kevo420 S-Series Tech 8 08-22-2013 06:06 PM
mystery connector samsr L-Series Tech 6 05-21-2012 11:05 PM
mystery connector.. I changed engine but cant remember where this came from! fixityourselfer S-Series Tech 2 03-25-2012 02:56 PM
Marvel Mystery Oil is indeed a mystery. KSabo S-Series Tech 40 07-07-2011 09:34 AM
USA Today - VERY Positive article Today BobbyP Aura General 4 10-21-2006 03:17 PM
