Old 04-20-2017, 08:32 AM   #1
NewJericho
NewJericho is on a distinguished road
Default Unbolting master cylinder to make room
Hey all, here is my situation:
I recently replaced the valve body of my '96 SL2 and when we (me and my father-in-law) put the cover back and got the car all put backed together we noticed, after a day or two, that the car was leaking transmission fluid. Upon inspection, we found pooling on the valve body cover, come to find out three of the bolts were not locking in. They would start to feel torqued but would continue to spin. So now we are putting in helicoils to remedy this, however, one of the holes is just slightly under the master cylinder. So my question is this: can I unbolt the master cylinder without disconnecting it, to make room to install the helicoil or would that only add to my repair work? I appreciate your help.
Add to NewJericho's Reputation
Rate the quality of this post and help NewJericho reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NewJericho is offline   Reply With Quote
Old 04-20-2017, 08:56 AM   #2
Default Re: Unbolting master cylinder to make room
Yes, but don't then let anyone hit the brake. Only move the minimum required.
Old 04-20-2017, 08:56 AM   #3
As long as the brake lines are in good condition, which they usually are in that area, it's fine to unbolt the MC and push it to one side. If the lines aren't in good shape there's a good chance they'll just crack & break instead of bend, creating quite the headache.
Old 04-20-2017, 09:17 AM   #4
NewJericho
Thank you very much for the quick reply, Fetchitfido and OldNuc. I will check the lines before unbolting, and the car is on jacks so nobody should be in there pressing the break. Thanks again!
Clutch cylinder/ Master cylinder HELP!!!!!!!!! 97SATURNATOR S-Series Tech 3 01-17-2014 12:44 PM
CLutch master cylinder/slave cylinder azwesjr S-Series Tech 1 12-26-2013 09:26 AM
CLutch master cylinder/slave cylinder removal Tjflow S-Series General 7 02-17-2010 04:43 PM
GM May Shrink Lambda Crossovers to Make Room for Unibody Chevy Tahoe Replacement Charlie Outlook General 4 05-11-2008 12:29 PM
