Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 04-18-2017, 09:54 AM   #1
Geordieontheweb
Geordieontheweb is on a distinguished road
2007 VUE Green Line
Default Turn signal cancel problem?
On my 2007 Vue Hybrid. My left turn signal does not cancel after the turn has been made. I have ordered a new switch but are there springs in the steering assembly to mechanically trip the switch? I had a similar problem with an oldsmobile cutlass years ago and had to replace a broken spring.... ??
Last edited by Geordieontheweb; 04-18-2017 at 09:55 AM.. Reason: Forgot to add car info..!!
Add to Geordieontheweb's Reputation
Rate the quality of this post and help Geordieontheweb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Geordieontheweb is offline   Reply With Quote
Old 04-18-2017, 11:34 AM   #2
pierrot
pierrot's Avatar
Default Re: Turn signal cancel problem?
Welcome to SaturnFans, Geordieontheweb! The turn signal/headlight switch has the turn signal cancel springs built in to it. You don't have to remove the steering wheel as it was necessary to do with older model vehicles. Be sure to disable the steering wheel airbag by disconnecting the battery, or pulling the related fuse to avoid its accidental deployment while replacing the switch.
284,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 04-29-2017, 10:46 AM   #3
far2grumpy
far2grumpy's Avatar
Turn signal cancellation functions are part of switch except cancel slots which are part of steering column ... bad slots would cause cancel problems for right or left turns.
Many Vue model years have choice of two switches - with or without auto-headlamps (AHL) - I imagine your 07 has AHL.
I've changed several of these switches through the years - hook a finger into opening above wiper switch and give good upward tug to expose the switch and connector.
I never worried about deploying airbag as long as you don't use a axe to remove the old switch.
Turn signal switch cancel? 700+SL2 L-Series General 1 03-28-2016 08:21 AM
Turn Signal Auto Cancel T-Bone 2008 Vue 3 05-29-2010 08:08 PM
Turn Signal doesn't cancel Toe Ion Tech 4 06-09-2008 04:31 PM
Turn signal problem-PLEASE HELP!! mac99sl2 S-Series Tech 3 02-19-2008 09:31 PM
2003 Vue Turn signal cancel problems majacoby Vue Tech 0 04-01-2007 08:40 PM
