Old 04-11-2017, 11:43 AM   #1
mangler66
mangler66 is on a distinguished road
mangler66's Avatar
2007 VUE 2.2L
Default New lowering springs : is there any rubber part I should also replace?
Well after 10 years in the salt my Eibachs have had it, and I ordered some new Megan springs. My question is what do people usually replace at the same time? I found a rear lower lower rubber isolator and definitely changing those, but what about the upper? Should I be changing the bump stop? Fronts look OK still, and strut bearings are still good, so I think I'm OK in the front.
2.2L 5 speed, Eibach springs, Centerforce Df clutch, OBX LSD, ES poly sway bar bushings
Add to mangler66's Reputation
Rate the quality of this post and help mangler66 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mangler66 is offline   Reply With Quote
Old 05-12-2017, 08:21 PM   #2
mangler66
mangler66's Avatar
2007 VUE 2.2L
Default Re: New lowering springs : is there any rubber part I should also replace?
For those who are wondering the K160073 rear coil spring isolators from Moog fit like a glove on the Megan springs. I installed 4 of them and they fit just as well on the top and bottom of the springs.
Old 05-12-2017, 10:26 PM   #3
billysvue
Smart, Mine were almost shot when I installed my Megan's.
Change out your SB bushings, too? Easy swap at most any 4x4 shop with a generic size selection of Energy Suspension polybushings with mating strap/mount( get with zerks).
Then there's the SB end links... after that, you shouldn't have many more loose bits besides shocks and struts, suspension rubber bushings/Bjoints ,as they age.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 05-13-2017, 06:57 PM   #4
mangler66
mangler66's Avatar
2007 VUE 2.2L
Yep, I have ES rear sway bar bushings already, that I modified to be greasable (added a groove inside, a hole and a zerk fitting). Not as good as the fronts, that are factory greasable ES bushings, but better than nothing. They warn me when I need an oil change, they usually start to squeak after 10000 km without a greasing
need to replace front coil springs/replace struts too? dapper S-Series Tech 24 05-13-2015 01:42 PM
lowering springs sw2 kid S-Series Mods 6 04-15-2008 09:42 PM
lowering springs sw2 kid S-Series Mods 4 04-13-2008 04:59 PM
Lowering Springs Sl1tech S-Series General 4 09-25-2005 09:31 AM
