Go Back   SaturnFans.com Forums > Site Information > Support Forum for Canadian Saturn Owners
Old 04-10-2017, 06:38 PM   #1
jfenley22
jfenley22 is on a distinguished road
Default 03 Saturn ION 3 stumbles after letting off brakes
Hey there,
Have a 2003 Saturn ION 3 with A/t trans. Having this problem where once the vehicle warms up, it will start to hesitate and almost stall right aft letting off of brakes on initial acceleration. Noticeable really if I take my foot off the brake after coming to complete stop and let the transmission move the vehicle. Applying no gas. If I apply gas it sputters then takes off fine again until coming to a complete stop. There are not trouble codes and vacuum gauge reads perfect and responds perfect. Here are the items replaced to try and solve this.
Ignition switch
Intake manifold gasket
Ignition control module
Spark plugs and COP
Fuel filter
Both 02 sensors and catalytic converter (both tested bad)
Fuel trims were lean but return with last stated repair.
Tested
TPS
MAF
IAT
Any advice or avenue to test would be greatly appreciated
Add to jfenley22's Reputation
Rate the quality of this post and help jfenley22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jfenley22 is offline   Reply With Quote
Old 04-10-2017, 07:03 PM   #2
Default Re: 03 Saturn ION 3 stumbles after letting off brakes
Mileage? Cleaned throttle?
Old 04-11-2017, 08:48 AM   #3
jfenley22
Mileage is 144,000 and the TB has been cleaned.
Old 04-11-2017, 09:41 AM   #4
A fuel pressure and compression check are next. No one can tell you when a fuel pump fails after a new car warranty expires, the same for engine compression. Age related issues begins during and after manufacturers warranties run out. Unfortunately, long term ownership transfers problems to us shouldering any issues for repairs.
SW1 Stumbles & Dies When Brakes Applied Airhed S-Series Tech 14 02-15-2016 08:20 AM
Saturn Ion that Stumbles cdh1 Support Forum for Canadian Saturn Owners 1 04-09-2013 08:30 AM
Front Brakes vs Rear Brakes? Saturn S-series EvanVanVan S-Series Tech 25 11-14-2011 08:39 PM
Saturn SL2 2000 Stumbles on Acceleration.. freakerz S-Series General 7 03-25-2006 06:10 PM
1997 Saturn SC2 Stumbles Off Idle Dijital357 S-Series General 1 04-09-2005 07:43 PM
