Old 03-27-2017, 06:51 PM   #1
Vinylm
Vinylm has a spectacular aura aboutVinylm has a spectacular aura aboutVinylm has a spectacular aura about
1999 SL1
2002 L-Series 2.2L Sedan
Default Saturn SL1 Radio and bulbs
So I took off the faceplate of my Saturn Radio thinking I could replace the light bulbs. they are soldered to the main board.
Add to Vinylm's Reputation
Rate the quality of this post and help Vinylm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Vinylm is offline   Reply With Quote
Old 03-28-2017, 02:19 AM   #2
Saturn Night
Default Re: Saturn SL1 Radio and bulbs
www.car-part.com
Plenty of factory AM-FM-only units in the wrecking yards. When the bulbs go, it is best to replace the unit, but as you have done, just the whole faceplate can be replaced.
Make sure you do NOT damage your knobs. Most used radios will not have them, and you can only replace them by ordering from GM, to the "tune" of about $50(Mine were $41.52 + $16.95 shipping, for factory cassette + EQ, RPO UP6).
Saturn Night is online now   Reply With Quote
Old 03-28-2017, 10:03 AM   #3
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
You'd have to unsolder the bad bulbs, purchase new ones, then solder the new ones on. But before you could even begin, you'd have to remove the circuit board from the head unit housing. You can see in your picture the bent tabs that hold the board in place. I see three in your picture, but there could be more. You'd have to bend them out of the way to remove the board. And notice that the one on the bottom left is soldered to the board. So you'd have to de-solder that one before bending it out of the way.
It's a decent amount of work. But honestly, for as little as those OEM units cost on Ebay or a local salvage yard, you're probably better off buying a good, used replacement unit.
Good luck!
'97 SL1, 136K, Auto, Mint Green (SOLD 146K)
'99 SL2, 126K, Auto, Silver (SOLD 149K)
'97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K)
'02 SL2, 149K, Auto, Light Gray/Silver
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bachands is offline   Reply With Quote
gen 3 radio bulbs saturnsctwo S-Series Tech 8 10-29-2016 12:09 PM
Radio light bulbs Gripcon Aura General 9 03-16-2014 07:32 PM
light bulbs for a radio mmtphoto S-Series General 14 04-26-2011 11:29 AM
Light bulbs for the AC and radio cluster? turbobuick33 S-Series General 7 07-29-2005 05:36 PM
Radio faceplate/bulbs kev99sl S-Series Tech 7 10-29-2002 03:14 PM
