Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 03-26-2017, 12:32 PM   #1
Kwolfey
Kwolfey is on a distinguished road
Default 2008 Vue Hybrid belt noise on auto stop
I have a 2008 Vue Hybrid and the belt make a loud squeal when the vehicle comes out of auto stop.
I had to change the belt twice last fall because it was getting chewed up. Found the cause of the problem, belt tensioner mounting bolt was cracked allowing the tensioner assembly to tilt just enough to cause the belt to be out of aligment. When I went to remove the bolt it broke off.
I purchased a new tensioner assembly before working on the vehicle becuae I was not sure if the issue of the belt being chewed up was one of the pulleys having a bad bearing or not and wanted to make sure I had any part I may need. I got a new bolt and used the new tensioner assembly and replaced the belt. now everytime the auto start kicks in there is a loud squeal and sometimes the vehicle will not start on the first try, annoying.
When I got the new belt I noticed there is two types available one cheaper than the other by about half. I purchased the $25 belt instead of the $50 belt. Is there really any difference between the two belts aqnd could this be the cause of my problem?
Add to Kwolfey's Reputation
Rate the quality of this post and help Kwolfey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kwolfey is offline   Reply With Quote
Old 03-26-2017, 01:20 PM   #2
Default Re: 2008 Vue Hybrid belt noise on auto stop
As I understand your hybrid system, the starter/generator supplies electric starting during auto engine stop modes. No separate starter. If correct, this means the starting motor applies high torque thru the drive belt system to turn over the engine crankshaft. This also means an extra tight belt to allow belt starting compared to geared starting in conventional starting systems. The starter/generator would require a very tight belt drive system, more so than conventional drive belt systems.
Search threads (some threads suggested at the bottom of this page) for more info.
2008 Vue Hybrid Dual Belt Tensioner - HELP! gqvue08 Vue Green Line 11 02-16-2016 07:01 PM
looking at 2008-09 hybrid gaurdien Vue Green Line 0 03-24-2014 09:03 PM
2008 Vue XE 2WD - Belt Noise TDragon 2008 Vue 7 01-04-2009 05:41 PM
2008 Vue Hybrid not available in Canada? muad-dib Vue Green Line 6 03-07-2008 10:22 AM
2008 VUE Hybrid just showed up Pete93SL1M 2008 Vue 4 01-06-2008 10:21 PM
