Old 03-20-2017, 10:42 AM   #1
nowukno
nowukno is on a distinguished road
Default Need help with fuel filter on 1st gen....
I have a 1993 sl2 1.9 dohc. Recently done some work....valve cover gasket, spark plugs, plug wires, window regulator, pcv valve/grommet, crankcase breather hose & new air filter. Thanks to this sites help it all went smooth. Only left is the fuel filter. Location looks like a pain. I already bought a new one & it came with the upper fuel line already attached & it looks like getting under the car is the best approach. So I'm thinking i do this. Depressurize the fuel system , remove air intake & detach hose under there. Then remove 2 10mm nuts holding filter to frame, remove bottom side fuel line from filter then just to the opposite to install new one. Lastly just pressurize the system before starting. Am i missing anything? Hopefully goes smooth. Looks like a really tight space to work with.
Add to nowukno's Reputation
Rate the quality of this post and help nowukno reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nowukno is offline   Reply With Quote
Old 03-20-2017, 11:44 AM   #2
billr
Default Re: Need help with fuel filter on 1st gen....
You are on the right track. The system pressurizes itself every time you turn the key on; do that (on-off-on...) before trying to start the first time. Also, you can check for leaks peacefully, without the engine running. Access is a bit tight, but not as bad as many other jobs. As I recall, I had my wife up on top to grab that hose and tuck it into the proper location, rather than just trying to shove the hose up there. Do you like how that sounds?
Add to billr's Reputation
Old 03-20-2017, 04:02 PM   #3
nowukno
Just to follow up my own post... Changed the filter just now and was actually really easy after removing air intake. Only thing that was kinda weird....after install i pressurized the fuel system by turning the key on/off a few times. Then i checked for leaks and took it for a drive down the road. For about the first mile whenever i pushed in the clutch the motor would rev to around 3000 rpms. After about a mile it cleared up and its fine now. Wonder what that was?
New fuel pump/filter no pressure out filter????? Justross1979 General Saturn Discussion 14 06-11-2017 12:11 PM
Parts Master fuel filter vs Wix fuel filter AprilSL1 S-Series Tech 21 08-05-2014 08:43 PM
My fuel filter arrived! Could it increase fuel economy and Power? Nick96'SL2 S-Series Tech 22 04-30-2011 10:28 PM
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 06:29 AM
Fuel injector? Fuel filter? Air filter? LoveMySaturn Miscellaneous Tech 13 05-14-2004 09:14 PM
