Old 03-12-2017, 02:30 PM   #1
registerednerd
registerednerd is on a distinguished road
Default 03 Glass Cockpit mod
So, the speedometer in my Vue failed (seems to be either the ECM or BCM. My mechanic brother says he doesn't see it being the ECM, and I don't want to have to deal with programming a BCM, but I can still read the speed off of the OBDII), so I'm toying with the idea of modding it to have a glass cockpit (all the instruments on electronic displays in the cluster). I'm going to run it with a Raspberry Pi, and I've got the CAN hardware on the way to start experimenting with it.
I'll document my progress here, and may chime in for assistance from time to time. First thing that I'm surprised to have so much trouble finding: does anyone have the pinout for the instrument cluster connector?
Add to registerednerd's Reputation
Rate the quality of this post and help registerednerd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
registerednerd is offline   Reply With Quote
Old 03-15-2017, 08:44 PM   #2
spenser4
spenser4 is on a distinguished road
Default Re: 03 Glass Cockpit mod
I attached some diagrams for you. Also FYI if you are seeing speedometer off the OBDII diagnostics. Then it's the instrument panel that is bad.
Add to spenser4's Reputation
Rate the quality of this post and help spenser4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spenser4 is offline   Reply With Quote
Old 03-15-2017, 11:33 PM   #3
registerednerd
Thanks for the info!. Yes, after prodding around under the dash a bit the other day, it does appear that it was probably the servo not making a good connection to the board, it's working now. That said, I'm still going to keep working on this idea, just because I think it's a cool mod, and should make for a fun project.
Old 03-16-2017, 06:20 PM   #4
spenser4
NP if you do the mod would like to see what it looks like.
Old 04-20-2017, 11:30 PM   #5
04Vuesilver
04Vuesilver is on a distinguished road
2004 VUE Red Line
I'd like to see this done too
Add to 04Vuesilver's Reputation
Rate the quality of this post and help 04Vuesilver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
04Vuesilver is offline   Reply With Quote
ION Cockpit Update..... IonCannon Ion Mods 5 08-10-2013 12:30 AM
2nd gen sl glass for 10 each in WI Saturninin S-Series General 2 07-22-2009 09:35 PM
glass? dorisSL S-Series General 18 07-06-2009 07:47 PM
glass pack dennish541 Aura General 28 01-14-2009 04:02 AM
glass drill_bit S-Series Tech 1 08-16-2007 10:43 PM
