Old 03-06-2017, 11:52 AM   #1
Banson
Banson is on a distinguished road
Default Key won't turn to shut engine off
I started the car, but now the key won't turn back the shut off the engine. The engine is still running.
It's a 92 Saturn SL1.
Edit: Sorry I didn't mention this is an automatic.
Add to Banson's Reputation
Rate the quality of this post and help Banson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Banson is offline   Reply With Quote
Old 03-06-2017, 12:02 PM   #2
Default Re: Key won't turn to shut engine off
5spd's are easy to shut off, hold the brake put it in any gear and drop the clutch.
Not sure what you can do in an automatic...must be a fuse to pull, maybe "IP BATT" in the underhood fuse box.
This doesn't fix needing to replace the ignition cylinder though. This thread may help with that: http://www.saturnfans.com/forums/sho...d.php?t=169876
Old 03-06-2017, 12:08 PM   #3
Banson
Thanks for the thought, sorry I didn't mention that it is an automatic.
Old 03-06-2017, 12:24 PM   #4
RobertGary1
Fuel pump relay?
-Robert
Old 03-06-2017, 01:30 PM   #5
PCM-B fuse?
Make sure shifter is solidly in Park, wiggle steering wheel, see if that allows the key to turn?
Old 03-06-2017, 03:05 PM   #6
Banson
Pulling the PCM-B fuse stopped it.
Thanks Everyone.
Old 03-10-2017, 10:36 AM   #7
TomM96
sometimes a drop of oil in the lock cylinder will free it up
they tend to stick intermittently-- mine did so in the parking lot of the dealere before i bought it in 2008 (@150kMI) , and still does.
Wiggling the wheel and occasional lubrication of the cylinder, help.
The cylinder needs to slide In/Out, as well as rotate.
Add to TomM96's Reputation
Old 03-10-2017, 12:57 PM   #8
toggenburg
toggenburg's Avatar
Graphite is better, does not gum up.
Tho, I have wondered if dry Teflon (PTFE poly tetra fluoro ethelene) may be even better.
Old 03-10-2017, 02:40 PM   #9
RobertGary1
+1 on Graphite. I wouldn't put anything wet in there.
-Robert
94 SC1 was running then engine shut off mattz164 S-Series Tech 1 05-17-2011 01:22 PM
Engine grunt during shut off (3.5 V6) jaygee Vue Tech 2 01-19-2011 12:05 AM
93 SC2 Electrical and Engine Shut-Down ilfyrfytr S-Series Tech 8 07-25-2008 11:14 AM
Shut off and turn on air cond. for unit health? JerryHughes S-Series General 19 07-27-2005 02:44 AM
Engine won't shut off trailpimp99 S-Series General 12 02-22-2005 07:39 AM
