Old 02-28-2017, 08:05 AM   #1
bbender
bbender is on a distinguished road
Default P0107 map
I have a 1999 Saturn SL2. It runs poorly (limp mode?). Codes are: P0107, P0341 and P0404. I am most concerned with the P0107. I have replaced the MAP sensor with no change in condition. I have checked the 3 wires in the MAP sensor and I have good power, ground and signal.
I am thinking the problem must be the signal wire between the MAP sensor and the PCM. I will check that next. Anything else I should be checking? Thanks!
Add to bbender's Reputation
Rate the quality of this post and help bbender reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbender is offline   Reply With Quote
Old 02-28-2017, 09:00 AM   #2
Default Re: P0107 map
That would be a good thing to check. Verify that intake manifold pressure is actually reaching the MAP as well.
Old 02-28-2017, 10:14 AM   #3
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Another example of where live-data can check it (the MAP system, in this case) in mere seconds.
Add to billr's Reputation
P0107 and P0171 bldzrr S-Series Tech 1 08-24-2016 09:48 PM
p0107 DTC Wallyb87 Ion General 2 03-19-2015 05:44 PM
PLEASE HELP!!! Code p0107!!! Acrite3404 S-Series Tech 5 07-12-2014 11:38 AM
