Old 02-21-2017, 03:10 PM   #1
xdarkxfirex
xdarkxfirex has a spectacular aura aboutxdarkxfirex has a spectacular aura aboutxdarkxfirex has a spectacular aura about
Default Jumping idle on astra?
Have had this problem. On friday it got worse when I was at a light. Usually the jump is pretty small. I cleaned the throttle body well, and booster hose, and same problem.
Could it be the internal IAC or MAP sensor?
Add to xdarkxfirex's Reputation
Rate the quality of this post and help xdarkxfirex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xdarkxfirex is offline   Reply With Quote
Old 02-23-2017, 08:35 AM   #2
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Default Re: Jumping idle on astra?
Is it a jump or a drop? I've experienced an occasional drop at a stoplight for the last 6-7 years (feels like it's going to stall, but doesn't). It's never been something that happens often (maybe 2-3 times a year), and it seems to happen completely randomly, so I guess I haven't worried about it. I think others have had the same experience. I've never experienced a jump though.
Drives: 2014 Volt, 2015 Acadia
Past Cars: 08 Astra, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 02-25-2017, 06:31 PM   #3
xdarkxfirex
Apparently I talked to a mechanic about it and he says its the pcv valve built into the valve cover. He said if your engine runs rough when you pull out the oil cap, its a bad pcv. I've confirmed its likely the culprit because the pcv hose spits out more oil than usual. They are cheaply built it seems and go bad, and it isnt easy to replace just the pcv, unless you can risk getting a cheap quality one from china. At the moment, im trying to get an aftermarket aluminum because I hate the idea of having cheap plastic valve covers that can break when you pull them apart.
http://www.saturnfans.com/forums/sho...d.php?t=161433
Old 09-29-2017, 12:54 AM   #4
Brianvande
Brianvande is on a distinguished road
Brianvande's Avatar
2008 Astra XR
I've had some really bad ones here and there. I'd would just try some premium gas and see if it improves.
2008 Saturn Astra XR3 5-Speed
Add to Brianvande's Reputation
Rate the quality of this post and help Brianvande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brianvande is offline   Reply With Quote
Clicking sound from motor while running idle Astra 2009 WilliamP Support Forum for Canadian Saturn Owners 0 04-06-2016 11:53 PM
2008 Astra XR 4-Door, Rough Idle & Error Codes IMay1280 Astra Tech 15 01-07-2016 11:00 PM
Rough idle, RPM jumping theMaudDib S-Series Tech 16 02-25-2013 11:07 PM
Engine RPMs jumping at idle davistl64 S-Series General 2 03-25-2011 09:18 AM
Jumping RPM marwanco Vue General 4 10-23-2010 03:33 PM
