Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Red Line
Old 02-21-2017, 06:09 AM   #1
kingkevin8
kingkevin8 has a spectacular aura aboutkingkevin8 has a spectacular aura aboutkingkevin8 has a spectacular aura about
kingkevin8's Avatar
2005 ION Red Line
2002 VUE 2.2L
Default Spark plug very tight
I had trouble removing a spark plug out of one of the cylinders. After using some pb blaster and working the plug back and forth, the plug then came out.
While trying to install the new plug it was just as tight going in. I really didn't know any other way to try and install the plug without force. So I torqued the other 3 to spec and measured all 3 from the top of the plug to the exit of the hole. I then kept tightening the tight plug until it also reached the same depth. Any ideas on this?
The tight plug was probably hitting the range of 50 ft lbs. I did use anti seize on the threads.
1995 Saturn SL2- 232,000mi
1993 Saturn SL2- 302,000mi
1994 Saturn SL2- 139,000mi
Add to kingkevin8's Reputation
Rate the quality of this post and help kingkevin8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kingkevin8 is offline   Reply With Quote
Old 02-21-2017, 07:52 AM   #2
billysvue
Default Re: Spark plug very tight
It could bethat the old set was left intoo long and the threads in the head were damaged. At least you were able to install.
How long will your existing plugs last before you have to install a new set? Install'd copper, platinum or iridium?
Leave well enough alone until then.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 02-21-2017, 06:19 PM   #3
kingkevin8
kingkevin8's Avatar
2005 ION Red Line
2002 VUE 2.2L
I installed iridium plugs.
Thanks for the reply.
I just made sure to load up on anti seize for the tight plug.
I bought the car from someone who has the car sitting in a garage for a couple years. So who know how long he has the plugs in the car.
The car has 80k miles
Old 02-21-2017, 06:36 PM   #4
billysvue
YOu should be good for over 50 K miles, then.
'17 Suby Forester
Old 06-28-2018, 01:20 AM   #5
Alexferguson
Alexferguson is on a distinguished road
So I finally got my new replacement pump from amazon $95 bucks, after swapping them out I took the old one apart and found that the steel bell was broken into 4 pieces, the impeller is magnetic driven, see pic, also I am thinking about doing a color change when I paint it, black now, want something that pops but not to bright, haven't decided on when to do it but I know less than 6 k where built just thinking ahead
Add to Alexferguson's Reputation
Rate the quality of this post and help Alexferguson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alexferguson is offline   Reply With Quote
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto.com General Saturn Discussion 0 01-12-2017 11:07 AM
2001 Saturn Auto Transmission Filter - How tight is too tight? ErikTande S-Series Tech 17 09-23-2016 05:52 AM
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 07:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-19-2011 11:52 PM
1998 sl2- oil where the spark plug boot meets the spark plug in 1st cylender scrapmedallord S-Series Tech 7 08-14-2009 11:31 PM
