Old 02-17-2017, 10:11 PM   #1
bushbr89
bushbr89 is a jewel in the roughbushbr89 is a jewel in the roughbushbr89 is a jewel in the rough
Default 2005 Vue Bouncing Speedometer
I just had the engine replaced in my manual transmission 2005 Saturn Vue. Last week I experienced periodic failure to my power steering, and then periodic power loss. After inspection my friend and I found that the ground wire by the fuse box was not properly tightened. Tightening the nut down solved that problem.
The problem I bring to you today and the reason I finally made a profile here is that now the speedometer will bounce erratically and at high speeds and starting from a stopped position the acceleration will jump as if from poor shifting.
I looked up the problem and found most people suggested replacing the speed sensor. I have just done that but the problem still is there.
TL;DR: Manual transmission, speedometer bounces from 40 -130 while driving and sometimes while stopped in neutral, acceleration jumpy at high speeds and while going from stop. Replaced VSS, did not fix problem.
Add to bushbr89's Reputation
Rate the quality of this post and help bushbr89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bushbr89 is offline   Reply With Quote
Old 02-18-2017, 11:23 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2005 Vue Bouncing Speedometer
If I were troubleshooting I'd use code reader/scanner compatible with Vue (must be able to read KWP) and monitor MPH at the OBDII port under dash.
If speed readings are stable it probably mean VSS to ECM wiring is OK and ECM is able to process the information. The ECM passes speed signal to BCM which then feeds to instrument panel cluster (IPC).
I'd also monitor the IPC odometer and if mileage appears to be recording normally it probably indicates the VSS, ECM, BCM, IPC path is good but problem is within the speedometer needle driving circuits.
However, if MPH reading at OBDII is also jumpy I'd suspect VSS, VSS to ECM wiring or perhaps internal ECM problem.
I've attach simple wiring diagram of VSS to ECM wiring ... looks like a single purple/white wire and IIRC at least one DIY'er pinched the feed wire to ground during a clutch change ... you may want to check that.
To continue, you probably transplanted your original ECM to the new engine so make sure the ECM external ground wire is present and connected to one of 4 bolts holding ECM to engine block.
Finally, are you saying that the engine throttle - will at times - try to add speed without input from you?
If yes - this indicates electronic throttle control system has a flaw of some sort. The VSS input to ECM is in play if the cruise control is turned on and a preset speed level is selected. You could post more information about the uncommanded acceleration.
Old 02-18-2017, 01:33 PM   #3
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
You need to look at a couple more grounds. Look at this link, I had similar problems with speedometer.
http://www.saturnfans.com/forums/sho...d.php?t=216101
Add to waiter21's Reputation
Old 03-03-2017, 02:57 PM   #4
bushbr89
thanks Waiter21 for the link.
All fixed
now it seems like i need to replace the rotor
Bouncing 2k-2.9k in park core S-Series Tech 8 07-26-2015 01:06 PM
2005 speedometer inop smelland Vue General 0 05-31-2015 06:00 PM
Bouncing Speedometer, but everything else works fine 2NDSOUT S-Series Tech 1 08-26-2013 09:26 PM
bouncing speedometer after VB rc1488 S-Series Tech 0 11-27-2007 10:32 AM
the bouncing speedometer Psyco88 S-Series General 2 11-21-2006 11:01 AM
