Old 02-17-2017, 02:11 PM   #1
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Default Rough start, good idle
2007 3.5 auto 120K miles. Don't know if the valves have been adjusted. Going to do that as soon as it is warm enough outside.
The car has been running great with 25 -28 mpg freeway. Pops up the p0300-p0306 codes like a lot of these cars do, but has no drivability issues. Always starts.
Yesterday it gave a one time afterfire on starting like a late ignition timing. After work on starting it started up and bucked once like an early ignition event.
MIL light flashed so I shut it off and restarted it. Started up fine with no light.
Since otherwise it runs great I am suspecting a CKS or dirty tone ring problem. Possibly a EGR issue.
Has anyone else had this problem?
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
Old 02-18-2017, 11:40 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Rough start, good idle
Try turning key to ON/RUN until IPC finishes selt-test and then advance to crank engine for a few cold engine starts.
You could be looking at a flaky fuel pressure regulator which is "bleeding" pressure from fuel rail at faster than normal rate.
Low pressure in rail will tend to dribble raw fuel into cylinders during a cold crank rather than the vaporized mix needed for smooth starts.
I attached a fuel pressure gage to my daughters 07 3.5 Vue when she reported similar problem ... I eventually had to drop tank and replace fuel pump to cure problem.
Rough idle when cold now won't start WheelingCJ5 S-Series Tech 11 12-08-2013 09:17 PM
97 SC2 5 speed - Rough Idle & Rough Start Jyounya S-Series General 2 07-05-2011 02:58 PM
Rough idle at start up tdapsr S-Series Tech 4 11-23-2009 02:19 PM
Rough start with intermittent low idle. NuitDeVotreMort S-Series Tech 5 08-01-2009 03:05 PM
'97 SC2, Rough Start, Rough Idle Right at Start maficke S-Series Tech 6 02-01-2007 04:35 PM
