Old 02-17-2017, 12:50 PM   #1
two_sl2s
two_sl2s is on a distinguished road
Default Power Steering-Variable steering or not?
I am changing the power steering pump on my 2002 SL2 DOHC Automatic
They keep asking if I have variable steering or not. I have searched sites where I give my VIN, but it still does not narrow it down. I found a note on the non-variable that says from VIN #TZ371463. My vin is 1G8ZK52792Z126018. Can anyone help with which power steering pump I need?
Only OneSL2Now
Add to two_sl2s's Reputation
Rate the quality of this post and help two_sl2s reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
two_sl2s is offline   Reply With Quote
Old 02-17-2017, 01:05 PM   #2
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Default Re: Power Steering-Variable steering or not?
A 3rd gen SL2 should have the variable pump. If there is an electrical connector plugged into the current pump, it is variable (EVO).
BV22
2002 SC1 5M
301k 12/17
Add to BV22's Reputation
Old 02-18-2017, 12:24 AM   #3
The parts interchange is about as stupid as it gets when it comes to S-Series power steering.
Factory DOHC engine means Variable (ie: with EVO valve) power steering.
Factory SOHC engine means either no power steering at all or non-variable power steering.
You can swap pumps between the engines, but you also have to swap the bracket as there are cutouts/divots that only line up with the correct pump but mount to either engine. If the EVO valve isn't sent the proper PWM signal it doesn't do anything, you get full power 100% of the time (though on the SOHC's it adds a bit of complication to installing the ps fluid lines).
2006 Ion - Dealer did power steering recall service ... still losing power steering! lbi2000 Ion General 2 08-11-2014 10:39 AM
Variable assist power steering GlennCoco S-Series General 5 11-19-2009 11:45 PM
early SL's all variable effort steering? 2003MercMaraude S-Series Tech 0 09-24-2008 08:55 AM
Help me identify Variable Steering in a 96SC1 nocolourblue S-Series Tech 2 08-30-2006 03:48 PM
power steering leak/steering rack question Gadweller S-Series Tech 9 11-19-2005 02:18 PM
