Old 02-17-2017, 10:27 AM   #1
oharag
oharag is on a distinguished road
Default 1999 Saturn SL Odometer Not Working
Okay this will be my second Saturn SL. I just received a 1999 S SL from a friend. First thing I noticed is the Odometer is not working. This is a digital version I believe. Where there should be numbers it's just blank. I need this to work to get PA inspection. Has this happened to anyone on this forum? If yes how easy to fix? I'm hoping it's a fuse issue. I'm I correct to assume it's digital? There are no numbers displayed at all - so It's not analog.
The car is in the shop. The shop called and said they can just buy another Odometer for $200. Again, I'm hoping it's just a fuse.
Thanks
Add to oharag's Reputation
Rate the quality of this post and help oharag reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oharag is offline   Reply With Quote
Old 02-17-2017, 12:09 PM   #2
oharag
Default Re: 1999 Saturn SL Odometer Not Working
Thanks
Ok it's seems like it is working - though the backlight does not. That is why I can not see it at night. I did not bother looking at during the day. Anyone change the backlight for a digital OD?
Old 02-17-2017, 12:53 PM   #3
$0.50 for a bulb is a lot better than $200...lol
Guide:
http://www.differentracing.com/tech_...99cluster.html
If you're brave & careful skip the dropping the steering wheel down part. I did it that way once, then found it's not required if you're careful about how it comes out. I never broke one but have read of others that did.
Old 02-17-2017, 03:25 PM   #4
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Odometer bulb for Gen 2 with digital is #73.
The others are a #74...
However, I think a PC74 from Superbrights will fit just fine,
And you can change the backlights to a different color at the same time...
https://www.superbrightleds.com/sear...nt-bulbs/pc74/
2002 Silver SL2, manual, 5th gear swap (.605), 79,900 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 02-19-2017, 12:10 PM   #5
I think we've all replaced that odometer bulb
http://www.saturnfans.com/forums/sho...d.php?t=154888
I used a 74LL before I found out it was supposed to be a 73. Looks like I changed the bulb 6/2016 and it is still working today. The #73 is dimmer but supposed to have a much longer life.
In addition to the info on Low Saturn's differntracin site, richpin has a bunch of videos on YT - this one for removing the instrument panel
https://www.youtube.com/watch?v=6jXiwgm3bPg
The Saturn S series is exceedingly easy to work on, and well documented. We've had many newbies/non-mechanics come here to ask questions and then end up doing the work themselves when they realized how easy it was. And (no offense) many of those were women who generally don't work on cars.
I probably would have never tackled removing the instrument cluster had it not been for this forum (it was the first time I have done a panel removal)
As a new owner, I suggest you read the sticky thread in the general forum
http://www.saturnfans.com/forums/forumdisplay.php?f=79
#1 tip, check your oil frequently, and do not let it drop below a diamond or two on the dipstick before topping off
93 Saturn SL1 Trip/Odometer Quit Working Again SL19302 S-Series Tech 4 03-20-2015 09:40 AM
Why do the odometer stop working on 91 - 94 Saturn S-series?? donrob42 S-Series Tech 2 10-29-2011 06:14 PM
2000 Saturn SL Speedo/odometer stopped working after jump demoncamber L-Series Tech 1 05-02-2010 06:35 PM
1999 Saturn SL horn - new not working ysabeau L-Series Tech 4 09-07-2009 01:32 PM
98 Saturn SC2 Digital Odometer Quit Working Bostngirl S-Series Tech 5 05-23-2006 09:29 PM
