Old 01-30-2017, 03:01 AM   #1
Duhminic
Duhminic is on a distinguished road
Default Saturn SL manual Transmission fluid question
Hey everyone i have a question about the fluid on my manual transmission SL. It has 141,000 miles on it and its never been changed. I looked at the color and it still has some pink to it but it also looks dirty. Question is should i change it out? would it be better to?
Add to Duhminic's Reputation
Rate the quality of this post and help Duhminic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Duhminic is offline   Reply With Quote
Old 01-30-2017, 03:25 AM   #2
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Re: Saturn SL manual Transmission fluid question
I consider manual tranny fluid a 100K item,
so at 140K, I would change it.
Use a Dexron III fluid, not Dexron VI,
2.7 quarts...
2002 Silver SL2, manual, 5th gear swap (.605), 78,000 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 02-03-2017, 11:55 AM   #3
Highmile
Highmile's Avatar
what he said
highmile
'95 SL1 622k and counting
Add to Highmile's Reputation
Old 02-03-2017, 01:33 PM   #4
TXSaturn02
TXSaturn02's Avatar
Use your best judgement. Several of us on this forum (including BV22 and myself) have well over 200K (I'm nearing 219K and BV22 is well over 250K IIRC) on the original transmission fluid. The owner's manual clearly states that 'no maintenance required' on 3rd gen and even the 1st gen read, "replace once at 6K miles". Hence, I personally wouldn't sweat it much.
New owner As of 01/01/18: 225,000 Miles
As of 03/20/18: 46,135 Miles
Old 02-03-2017, 02:25 PM   #5
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Shifts like butter at 284 k, but don't adopt my laziness. I'm very gentle to my transaxle, and live in a warm climate.
There is no harm in changing the fluid as long as you use the correct grade, but as TXSaturn suggests, you can go a while longer if need be.
BV22
2002 SC1 5M
305k 02/18
Add to BV22's Reputation
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 06:47 PM
2000 Saturn LS1 Manual Transmission Question ward4440 L-Series Tech 10 03-01-2013 04:43 PM
Manual transmission fluid? Saabstealth S-Series General 21 06-17-2012 11:48 AM
91 SC - Manual Transmission Fluid RGZ S-Series Tech 43 03-27-2011 03:51 PM
2003 Saturn VUE Manual Transmission Fluid sinhlee Vue Tech 3 10-03-2007 08:25 PM
