Old 01-25-2017, 04:11 PM   #1
tyeayo
tyeayo is a jewel in the roughtyeayo is a jewel in the roughtyeayo is a jewel in the rough
Default No brake lights working..all others work..need help!
None of my brake lights are working.
The leds are working for the running lights, but do not brighten when the brakes are engaged.
I checked the fuses
All visible connections
Swapped relays
Replaced brake position sensor
Not sure if my third brake light has ever worked since i bought it 2 years ago.
The other day my daughter slammed the crap out of my trunk, i THINK that has somethung to do with this.
Any idears or suugestions? I'm gonna tear into it deeper tonight, remove the rear deck, test for voltage at the connections, look closer at the 3rd brake light....just stumped at ths point on what it couod be.
The leds are good, and are getting a signal to illuminate for the running lights, but evidently not for the brakes.
Thanks for the advice gents
Add to tyeayo's Reputation
Rate the quality of this post and help tyeayo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tyeayo is offline   Reply With Quote
Old 01-25-2017, 04:14 PM   #2
billysvue
Default Re: No brake lights working..all others work..need help!
Do the lights work if you install regular bulbs?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 01-25-2017, 04:17 PM   #3
tyeayo
The brake lights are an led strip, i dont know how i wouod go about put in bulbs...
Old 01-25-2017, 04:20 PM   #4
tyeayo
Are you talking about trying to wire into the harness a regular bulb harness? I could try that, but it wouod be the same as when i hook up a volt tester.....
I have a fluke, but the probes are too big to fit inaide the harness to test for voltage
Old 01-25-2017, 05:03 PM   #5
As you know, running lights are separate from brake lights and are on separate circuits. With ignition OFF, I think every vehicle is wired so anyone pressing the brake pedal will turn on rear brake lights - probably a safety issue when brake lights were designed to work with the brake pedal regardless of ignition switch position. The same can be said of manually turning on running lights, low and high beams without using the ignition switch. With this mind, your brake light circuit is the problem; brake pedal switches nowadays have at least two switches; one for the brake lights and the other for cruise control, the bcm where brake switch signaling goes to and output from the bcm to maybe a relay to power the brake lights. Presuming the bcm is fine leaves the brake switch by brake pedal and wiring at the rear brake lights.
Since brake lights are separate circuits from running lights, someone may have to press the brake pedal down while you probe each brake light socket for 12 volts. Be sure to test brake lights, not running lights. If you're lucky it may be a faulty brake switch and not wiring. The third brake lights are also wired as a separate circuit but run is parallel with brake light wiring so three sets of lights turn on for braking.
Old 01-25-2017, 07:31 PM   #6
tyeayo
Thanks for that fdryer
I dug in deeper, and pressed the brake down with a bar, and tested for 12v to the brake lights, with the drl on i got 12v, with them off i got nothing....this is telling me there is a problem with power getting back to the lights when braking....
I swapped out the brake switch yesterday, and i even removed it from the bracket and had a buddy swivel it around and still no juice to the lights....I'm really stumped right now, only thing i can imagine is the NEW switch is also bad....do you know how i could go about testing that?
Old 01-25-2017, 08:32 PM   #7
I'm not an expert on switches but like most simple switches they're configured in one of several ways. Typical brake switches are momentary types - normally off (no braking) and on (braking) as long as the switch is held in/on as a brake switch is used. I do not have wiring diagrams for Aura's so you might be able to use this link to find wiring for your Aura (if not the exact year but wiring should be the same for all Aura's); http://workshop-manuals.com/. I can only guess two wiring circuits, the one already mentioned using the body control module and conventional brake wiring without going thru the bcm.
Conventional wiring wouldn't need the bcm and wired indirectly thru a relay or directly to the brake lights. My guess is wiring is thru a relay; the brake switch supplies either a ground or 12v to the brake relay, powering the relay and a set of contacts closes to send ground or 12v to the brake lights, including the third brake light.
Old 01-25-2017, 09:42 PM   #8
tyeayo
Its actually a rheostat...which makes me more nervous cause i wasnt able to read any voltage feeding it from the harness....such a pita....i got an appt to drop it off tomorrow....as much as i hate that....its so wierd....
No voltage to 3rd brake light
No voltage to either tail brake light
But the leds get voltage when the drl is on.....
Something is stopping a signal from the brake positiom sensor and the brakes
Old 01-25-2017, 11:39 PM   #9
Really?! That's a new one as I'm under the assumption brake switches are simple on/off devices.
No voltage to brake lights is one thing, the daytime running lights are not supposed to be controlling the running lights, period. Daytime running light are supposed to be controlling the headlights, only. This suggests someone modified wiring or the led running lights are configured incorrectly and interfering with the running light circuitry and/or brake light wiring............ If you can remove these leds and return to stock running lamps, see if this corrects the running lights and brake lights.
Something is stopping a signal from the brake position sensor and the brakes
The led lights interfering with running and brake lights? Remove and replace them with stock lamps. Be sure the original stock lamps are for running lights. Some tail lights combine two lights into one bulb while others have separate tail and brake lights.
Old 01-26-2017, 11:06 AM   #10
tyeayo
All Saturn's have led brake lights...
The running lights light the brake lights, and when you step on the brakes, its lights those led brake lights brighter....this is the normal operation...if you go check yours, you'll see that the brake lights are an led strip, and when your running lights are on, the brake lights light up, but when you press the brakes, they light up brighter
Old 01-26-2017, 11:14 AM   #11
billysvue
Maybe later model ones do- not older.
'17 Suby Forester
Old 01-26-2017, 01:02 PM   #12
Are you sure of this? Saturn as a brand isn't a high end vehicle where LED lighting is costlier in factory installations. My L300 uses plain incandescent lamps. One way to know which lamps are used - going online and visiting AutoZone, Advance Auto, NAPA, etc., and looking up replacement tail lights. The previous owner may have modified lighting to accommodate LEDs, resulting in this problem along with losing the third brake light. Most custom wiring may use wire taps, cut and splice, and leaving loose wiring not resembling factory configurations with electrical tape unraveling after a few years. Custom wiring tends to stand out.
Old 01-26-2017, 07:08 PM   #13
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
this is probably a dumb comment but just want to make sure you know on aura car has to be running for brake light s to work. sorry if you already knew that
Add to onefunkar's Reputation
Old 05-29-2017, 11:38 AM   #14
tyeayo
beyond sure, as i've replaced both sides for the lens popping off and scavenged the internals as spares....they have an led strip for the brake light...bulbs for turn signal and reverse light...
turned out that one of the leads going into the trunk fuse box came loose....foolish of me to not inspected deeper...
Old 09-25-2017, 07:10 AM   #15
langdon4204
langdon4204 is on a distinguished road
where would i look for a loose lead going into the fusebox? I have the same exact issue right now with my Aura and can't seem to figure it out. I don't know if the brake lights run on a separate fuse and if so which fuse that would even be. thanks.
Add to langdon4204's Reputation
Rate the quality of this post and help langdon4204 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
langdon4204 is offline   Reply With Quote
Old 02-12-2018, 05:32 PM   #16
tyeayo
its the fuse box in the trunk, on the driver side....
you gotta peel back the carpeting and there it is....reach around in there and see if you have any loose connections.
None of my brake lights are working on my 03 lw300 Jonw943 L-Series Tech 2 08-02-2015 11:00 AM
2004 Vue AWD Brake lights don't work qigongdoctor Vue Tech 3 12-23-2014 07:47 PM
left and right brake lights don't work but centre high brake light works. microsat S-Series General 15 01-08-2014 10:44 PM
No dash/running lights, but DTR, Hi/Low, brake/signal lights work??? Haybale S-Series General 1 08-09-2013 11:49 PM
help please- brake lights not working jcono Vue Tech 11 09-28-2006 09:43 PM
