Old 01-13-2017, 06:43 PM   #1
SpockNard
SpockNard is on a distinguished road
2001 SL2
Wrench SL2 Map Light Fix
I have read many posts re: broken, chintzy map light switches, and no one has found replacement parts- I have, and just fixed my son's map lights. I found the items via Mouser.com- one of my go-to places for small electronic parts. See pix. The switches are Mouser P/N 611 PS12-G03. The connectors that fit the switches are P/N 571 770983-1. No minimum for switches, minimum strip of 100 connectors.
I won't review whole procedure to remove fixture, etc., but one mod, to allow switches to snap in right, was that I sanded down a ridge on the back of the housing that kept the new switch from snapping in right- quick dremel job.
I've screwed around with the old switches more than once- the new parts fix feels much more secure, and parts cost etc. under $14.
Add to SpockNard's Reputation
Rate the quality of this post and help SpockNard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SpockNard is offline   Reply With Quote
Old 01-13-2017, 07:07 PM   #2
toggenburg
toggenburg's Avatar
Default Re: SL2 Map Light Fix
Warm welcome to the Forum!
Nice way to fix a common problem, Thanks!
Old 01-14-2017, 12:34 AM   #3
gveinot
gveinot is a jewel in the roughgveinot is a jewel in the roughgveinot is a jewel in the roughgveinot is a jewel in the rough
gveinot's Avatar
2000 SL2
2000 SL2
thanks for sharing,
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 01-14-2017, 12:50 PM   #4
Saturn Night
By "Map" light, are you referring to the "Dome" light above the seats?
Old 01-14-2017, 01:37 PM   #5
The map lights are only on sunroof equipped models, located directly above the rear view mirror: http://i28.photobucket.com/albums/c2...r/P3210144.jpg
For a car nut you really need to go JY S-Series hunting and actually check things out...lol
Old 01-14-2017, 07:10 PM   #6
subscribed for easy future reference, and bookmarked mouser.com. Thanks, and that's one heckuva great first post!
Now, back outside to the cold garage trying to undo the weird electrical s&!#* the previous owner did so I can drive this car
Old 01-14-2017, 09:19 PM   #7
SpockNard
2001 SL2
Glad it was worthwhile - real commonly posted issue. And yes, sun-roof model "map light", not dome light. I'm not very automotive-mechanical savvy, but I am a self-avowed "Mr. Fixit". And it's amazing how often switches are to blame.
random dashboard flicking , radio dash light out, cigarette bulb light out hlouis89 S-Series Tech 13 03-22-2014 03:27 PM
stuck in park, check engine light, brake light flashing Wemble Ion General 8 02-08-2014 04:38 PM
Service Wrench Light on, ABS light on, Rear Defrost stopped working lg540 S-Series Tech 10 10-30-2011 12:47 PM
ABS light turns on -> battery light flashes -> tachs tweak -> temp gauge fails = ??? veeare4 S-Series Tech 1 10-06-2011 06:58 AM
Weird one: passenger door fails to light dome light. tehSaturn S-Series Tech 7 09-09-2011 03:14 PM
