Old 01-10-2017, 10:03 PM   #1
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Default 01 SC2 Manifold Coolant pipe repair
01 SC2 had the coolant overflow -to-manifold nipple break off. I had the CARSATURN repair fitting on hand that I bought for another project and did not use.
Anyone here successfully trim the intake manifold without removing it from the engine? Seems like I remember somebody who tried to do this using either a hack-saw blade or a small cutting wheel.
Just looking for any input on this before we resort to pulling the entire manifold off.
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 01-10-2017, 10:07 PM   #2
Default Re: 01 SC2 Manifold Coolant pipe repair
It can be cut in place, be careful.
Old 01-11-2017, 01:54 PM   #3
I subscribed to these threads related to that repair - might be something in one of these:
http://www.saturnfans.com/forums/sho...d.php?t=228963
http://www.saturnfans.com/forums/sho...d.php?t=228658
Just bought a 3rd gen, so I was looking at possible preventative maintenance items
Old 01-14-2017, 10:48 PM   #4
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
I did the repair by removing the intake manifold around 3 years ago. I wonder now if I could have used a soldering iron to melt away the part to be removed. If you touched the head with the soldering iron, it would not hurt it like a hacksaw would. I am sure it would smell pretty bad while doing it though! I guess I would first melt off the nipple part, then place the metal replacement on top of what's left and paint the plastic where the metal part doesn't cover so you know how far to melt the plastic to make the repair part fit flush up against the manifold when on the head. It was an idea I recently had. Maybe someone can try it.
It's GOOD to have a spare!
Add to termite's Reputation
Rate the quality of this post and help termite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
termite is offline   Reply With Quote
manifold coolant repair tink65 S-Series Tech 4 05-11-2015 05:04 AM
Thermostat Extension pipe / coolant pipe yzracer14 Vue General 10 05-26-2014 10:03 PM
What is the AIR pipe on the exhaust manifold? linearbit8 L-Series Tech 29 05-16-2014 10:57 AM
Removing front exhaust pipe from manifold, V6 cityhawk L-Series Tech 1 05-23-2012 12:42 AM
How to Remove Stud (Manifold to Exhaust Pipe) MickSaturn S-Series Tech 15 01-28-2007 01:25 AM
