Old 01-10-2017, 09:05 PM   #1
cpy911
cpy911 has a spectacular aura aboutcpy911 has a spectacular aura aboutcpy911 has a spectacular aura about
Default Temp gauge and P0118?
1996 SC2 DOHC with 82K. California car!
Driving home today in traffic and I noticed the temp gauge dropping to full cold then half then back to 1/4. It was erratic and fast changes. Then the computer threw a P0118 code which I reset and it did not come on again for the rest of the ride. I noticed some idle problems and then finally rolled into my garage at home and the radiator fan kicks on, the temp gauge goes erratic to cold and half and back and it revs up and down. Not overheating, just crazy stuff.
The car was new to me and I replaced the ECTS with a brass tipped one from Amazon.com about two months ago.
Could my replacement ECTS have gone bad? I used teflon tape and a in-lb torque wrench to install it. My scan gauge usually says I am running at about 150 degrees, but on way home I was at 125-130 and all over the place down to 100 degrees.
Should I replace with another ECTS? Any recommendations on a better one? When I first replaced ECTS, the temp gauge was between 1/4 and 1/2 now it is just barely above quarter all the time.
Thoughts? Car has been running like a dream until today...
Add to cpy911's Reputation
Rate the quality of this post and help cpy911 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cpy911 is offline   Reply With Quote
Old 01-10-2017, 09:26 PM   #2
cpy911
Default Re: Temp gauge and P0118?
I found my past order and installed a "Standard Motor Products TX73T Engine Coolant Temperature Sensor" brass tipped ECTS back in September.
Maybe it is dead now?
I am thinking maybe a Delphi or AC Delco might be in order?
Old 01-10-2017, 09:43 PM   #3
cpy911
Crap! Picture of the connector...it looks like crap green corroded. Going to splice another one in. Anything special about this?
Old 01-10-2017, 10:06 PM   #4
toggenburg
toggenburg's Avatar
Make sure you do solder splices and then cover with shrink tubing.
No twisted wires with wire nut splices will last.
Old 01-10-2017, 10:15 PM   #5
cpy911
Does it matter which wires I splice to? Or does it not matter?
Old 01-10-2017, 10:32 PM   #6
cpy911
Richpin for the win!
https://www.youtube.com/watch?v=mNZq6PuOi5c
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
Wierd Saturn L200 Gas Gauge/ Temp Gauge and change oil light probs! Crittercage L-Series General 1 09-09-2016 12:23 PM
P0118 and temp stuck halfway huffbanger S-Series General 19 02-07-2012 09:10 PM
Temp gauge polodude1017 S-Series General 20 01-12-2011 11:59 AM
Temp gauge and P0118 slonoma98 Vue Tech 6 01-03-2011 11:54 PM
