Go Back   SaturnFans.com Forums > Site Information > Support Forum for Canadian Saturn Owners
Old 12-30-2016, 10:41 PM   #1
bigcougar
bigcougar is on a distinguished road
Default Instrument cluster installation
I am considering installing a new instrument cluster on my LW1 if the installation is easy / inexpensive.
My concerns are that the new cluster needs re-programming. Is this the case?
The second issue I have is, I can only get US clusters where the primary speed reading is miles. Would this cluster still show me the correct speed in kilometers?
I wish I could just swap the two clusters myself and not have to rely on GM.
Add to bigcougar's Reputation
Rate the quality of this post and help bigcougar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigcougar is offline   Reply With Quote
Old 04-30-2017, 04:11 PM   #2
mtlsc1
mtlsc1 is on a distinguished road
2001 SC1
Default Re: Instrument cluster installation
ave you searched youtube? The procedure should be real easy and often (at least that was my case for my SC1) you don't need to remove anything other than the dash cover.
I believe the US cluster should show proper speed and I doubt that you need to reprogram the cluster as the information should all be coming from the computer.
2001 Sc1 1.9 SOHC
Towed less than a quarter mile in 17 years.
Add to mtlsc1's Reputation
Rate the quality of this post and help mtlsc1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mtlsc1 is offline   Reply With Quote
Old 05-08-2017, 10:35 AM   #3
bigcougar, examine your i/p cluster again. If I'm not mistaken, Canadian speedometers will have two overlays with kph in larger type face with smaller mph markings. Kph on the outer circle, mph in the inner circle. On USA clusters it's the other way around. The bigger problem is the odometer and how the bcm converts to miles or kilometers. With the xmission speed sensor an electrical signal, the bcm does the math and displays it. Other than using a USA speedo and reading the smaller kph numbers, replacing the i/p shouldn't be a problem other than the odometer issue. No Canadian junk yards or online sites for metric i/p clusters?
Instrument Cluster... Elementkng20 S-Series Tech 6 08-24-2007 04:25 PM
Help instrument cluster!!! amajn S-Series Tech 7 04-01-2007 02:56 AM
instrument cluster went to the *****er JC2002SILVERSC2 S-Series General 11 05-23-2006 12:27 PM
instrument cluster maxpeterson Ion General 34 06-04-2003 10:11 AM
Instrument Cluster Terrandus S-Series Tech 4 09-24-2002 08:19 PM
