Old 12-29-2016, 03:21 PM   #1
Gcd553
Gcd553 is on a distinguished road
2000 SL2
Dizzy 2000 SL2 crank, but won't start
I have read a few different posts in hopes I could solve my 2000 SL2 problem. We have replaced CPS, Spark Plugs, Wires, TCS, Fuel Pump and Fuel Filter. Checked timing chain, starter, spark, and oil for problems. Car turned off while driving and will not start...cranks and tries to start but doesn't. Any ideas?
Add to Gcd553's Reputation
Rate the quality of this post and help Gcd553 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gcd553 is offline   Reply With Quote
Old 12-29-2016, 05:03 PM   #2
SC2Sick
1995 SW2
Default Re: 2000 SL2 crank, but won't start
You need 3 things to run (more or less)
Spark
Fuel
Compression
Do you have spark?
Do you have fuel?
Have you run a compression test?
I'd also check the PCM B fuse under the hood (it's by the green 30A ones)
sixthsphere.com owner
1997 Saturn SC2 Turbo
sixthsphere.com/showthread.php/89737
Add to SC2Sick's Reputation
Old 12-30-2016, 07:04 AM   #3
Originally Posted by Gcd553 View Post
..... Car turned off while driving and will not start...cranks and tries to start but doesn't. Any ideas?
Did this occur before or after replacing parts? Remove spark plugs and check for fuel on them. Yes or no? And did you examine your coolant sensor? Original round nosed plastic ones fail and sends incorrect signals resulting in rich fuel mixtures and flooded starting. Replacing it with a flat nosed brass sensor cures this problem and many other issues related to rich running conditions.
Old 12-30-2016, 07:51 AM   #4
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Does the chime work that warns you the key is in the ignition? If you have a FOB does it work or did it mysteriously stop?
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
Old 12-30-2016, 01:03 PM   #5
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
^^ Good point, let's see what the OP says.
Old 01-07-2017, 08:43 PM   #6
Gcd553
2000 SL2
The vehicle shut off while driving before we started replacing parts. We started trying to fix it by having the starter checked (removed) and decided to replace CPS at same time. Didn't start...replaced spark plugs, wires and the TCS (non plastic). Still didn't start...so replaced fuel filter and fuel pump.
We are still puzzled...
Old 01-07-2017, 08:49 PM   #7
Gcd553
2000 SL2
Chime works when the key is in, there was no keyless option with the keys when we bought the car six months ago. Is there a way to check if it has an FOB?
Old 01-07-2017, 10:17 PM   #8
When the engine shut down on its own, did all instrument panel indicators drop dead too? While you're throwing parts at the car in hopes of striking a cure with no luck, you may be skipping all the basic things to check; all fuses between the two fuse panels, fuel on spark plugs after several failed starting attempts, and a visual spark test. Checking for fuel on plugs after failed starting attempts does several things; checks for injector operation, fuel pump running to generate pressure, verifies crank sensor operation, and pcm operation. Its a simple suggestion. The same for spark testing.
When testing for spark, spark indicates; the crank sensor is working, the pcm is working, and the ignition system (ignition control module and coils) are working.
Two simple tests of the EFI system. Feedback from results will determine which way to proceed, all without using parts.
2000 Saturn sl2 no start no crank KMW S-Series Tech 4 07-08-2016 10:57 PM
Saturn SL2 2000, Crank no start BrakeCheck S-Series Tech 1 10-11-2014 10:37 PM
No Crank, No Start for 2000 Saturn SL1 s.mac S-Series Tech 8 12-21-2013 07:30 PM
2000 Saturn LS1 Intermittent Crank-No Start DeUltima L-Series General 5 08-13-2013 12:44 AM
2000 SL1 won't start or crank at all 1tallguy S-Series Tech 1 02-04-2012 03:09 PM
