Go Back   SaturnFans.com Forums > Site Information > Support Forum for Canadian Saturn Owners
Old 12-06-2016, 08:40 PM   #1
bigcougar
bigcougar is on a distinguished road
Default Looking for small Discontinued parts
I am in Terrace, BC and will be replacing the rear control arms and bushings on my 2000 LW1. The problem now is I cannot order some bolts as they are discontinued.
For example bolt #19 below which is GM #09231141
Also looking for bolt #16 and possibly other bolts. What is a good reliable place to find these or replacements that would fit?
Add to bigcougar's Reputation
Rate the quality of this post and help bigcougar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigcougar is offline   Reply With Quote
Old 12-07-2016, 08:16 AM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: Looking for small Discontinued parts
Go to a good hardware store and pick-up some Grade 8 bolts, washers & nuts which match the GM hardware. Grade 8 Hardware matches or exceeds the strength of the GM parts.
Bring the bolt with you to the hardware store. If you do not have the bolt to compare, do some research on the length and dia needed.
Add to rb6667's Reputation
Old 12-07-2016, 12:00 PM   #3
These two sites are good for metric parts if your local Home Depot, Lowe's, whatever doesn't have them. A few minutes spent measuring the bolt for thread pitch, shank diameter and length should help you find a correct replacement. 10.9 is the strength for metric bolts.
Belmetric.com; https://www.belmetric.com/12mm-coars...6_510_406.html
BoltDepot.com; https://www.boltdepot.com/Metric_tap...m_x_1.5mm.aspx
Old 12-07-2016, 10:40 PM   #4
bigcougar
Thanks guys!
The local Canadian Tire store, which will also do the repair say they will find the bolts. I hope the whole procedure goes smoothly. It will be a $1,700 repair on a car that cannot be sold for more than $1,000 but what the heck; it is my car.
I figure it is better for our environment to drive small engine cars for as long as they last and my fuel efficiency is still 7 litters per 100km on the highway.
Old 12-31-2016, 11:36 AM   #5
cam
cam is on a distinguished road
cam's Avatar
2007 VUE 2.2L
2007 ION-3 Sedan
Try Rock Auto...they seem to have tons of discontinued parts from various auto makers but they are in the U.S. and you will have to pay shipping and taxes as applicable. Not to mention the exchange rate but give it a try.
Add to cam's Reputation
Rate the quality of this post and help cam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cam is offline   Reply With Quote
Discontinued parts saturnmommy S-Series Tech 5 05-05-2016 04:16 PM
Where to get discontinued parts jdsdls S-Series Tech 10 09-15-2015 12:25 PM
anyone know where to buy discontinued parts?? boatmoter S-Series Mods 2 01-10-2015 01:25 PM
Discontinued parts can be dangerous bobbyrae Suggestion Box 3 04-07-2008 01:24 PM
parts for discontinued sc models woppajoe Miscellaneous Tech 3 03-21-2003 02:35 PM
