Old 12-06-2016, 05:57 PM   #1
Jimmy123
Jimmy123 has a spectacular aura aboutJimmy123 has a spectacular aura aboutJimmy123 has a spectacular aura about
2002 SL
Default Idle drops very low, surges sometimes
So I was driving my 2002 Saturn SL SOHC today and noticed that after I drove home for lunch that my idle was dropping down lower than normal. It never stalled, but it just didn't seem like the RPM's were where they normally are.
I also noticed that in between shifting gears that the RPM's drop very fast, like down to 500 or 600, and it didn't do that before today. The car still drives just fine like it did before, other than it seems to buck a little bit sometimes when I let the clutch out for the next gear, but I'm very anal about little things like that and just wanted to get the opinions of the more experienced Saturn guys on here.
Add to Jimmy123's Reputation
Rate the quality of this post and help Jimmy123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jimmy123 is offline   Reply With Quote
Old 12-07-2016, 08:42 AM   #2
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Default Re: Idle drops very low, surges sometimes
If the Idle Air Control Valve starts to stick and not open when it should, you will experience an idle in the 400 - 500 rpm range. Clean the throttle body and IACV and see if the issue goes away. If not, the IACV itself may need to be replaced.
BV22
2002 SC1 5M
305k 02/18
Add to BV22's Reputation
95 SC1 Engine Surges at Idle tubeofglu S-Series Tech 3 11-10-2014 07:22 PM
Idle surges, once a month or so, replaced TPS cmpcpro S-Series Tech 9 03-17-2010 03:27 PM
My LW2 V6 Surges at idle LW2-2000 L-Series Tech 10 07-21-2008 07:10 AM
Engine surges upon startup and idle?? toddo S-Series Tech 2 11-25-2006 08:11 PM
idle surges, runs rich, 92 SL2 dennis S-Series Tech 9 08-29-2006 08:10 AM
