Old 11-19-2016, 05:20 PM   #1
1993
1993 is on a distinguished road
Default Coolant leak at plastic intake..help and dremel?
I have a 2001 SC2 and noticed when i cold start the car, it will drip a puddle of coolant under the car but then it QUITS dripping after the engine warms up. I traced the leak back to the plastic intake on the end that has the plastic heater hose nipple and read that area gives leak issues. Where is it that it cracks because this seems like its coming from the gasket between the manifold and head..?
Anyways, no way im taking that intake off to do the metal nipple conversion. I remember someone talking on here about leaving it on the car and using a dremel..if your here still, or anyone thats done it that way, please let me know how you did it as i am about to tackle it. I can get to it pretty well after removing the bracket beside the EGR and have a straight shot at it.
Add to 1993's Reputation
Rate the quality of this post and help 1993 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1993 is offline   Reply With Quote
Old 11-19-2016, 06:41 PM   #2
bluesl2
bluesl2's Avatar
Default Re: Coolant leak at plastic intake..help and dremel?
It sounds like you quite possibly have a 1st design intake gasket on your car. All of the 2000 model year dohc engines and some of the 2001 model year up to a certain VIN have an intake gasket that was prone to leaking. Usually it shows the same conditions your car is exhibiting. When the engine is cold, it leaks some and then when the engine is warm it stops leaking. The old gasket is a one piece design and the new one is a two piece design. You would be very wise to get a new gasket and the repair kit necessary to replace the plastic tube on the manifold that cracks and causes a leak. Don't be intimidated by taking the manifold off, it's actually very easy.
Add to bluesl2's Reputation
Old 11-19-2016, 07:13 PM   #3
1993
Huh?? it sure doesnt look easy...explain
Old 11-19-2016, 07:32 PM   #4
TXSaturn02
TXSaturn02's Avatar
What is easy for some (running a 5:00 mile), isn't easy for others.
Seriously, I don't think it is easy either. It MAY be easy, but very time consuming.
Though, I did learn something new. This only applies to 2000 and early 2001 DOHC models? Nice to know, since I have a 2002.
New owner report of 07/25/18: 229,023 Miles
As of 07/25/18: 51,495 Miles
Old 11-19-2016, 08:18 PM   #5
Video 1: https://www.youtube.com/watch?v=VSlKmjSVuK4
Video 2.1 (carsaturn p1): https://www.youtube.com/watch?v=-g4fX_MslJE
Video 2.2 (carsaturn p2): https://www.youtube.com/watch?v=7ESs2OAp0rs
Video 3 (leaves IM installed: https://www.youtube.com/watch?v=cy2ztwi8Tao
It's a tight fit and tricky to not nick the head while cutting (hence why removing the IM is reccomended...).
Old 11-19-2016, 09:05 PM   #6
1993
This is the one i want to do. Can i use a dremel and cut off that end of the plastic intake without having to remove it?
https://www.youtube.com/watch?v=blgRq_BXv8s
Old 11-20-2016, 04:11 PM   #7
1993
anyone? Also, if i can do this, how do i cut through the gasket, or is the gasket separate at that coolant end?
also, what is the flexible metal pipe for that is under the leaky area?
Old 11-20-2016, 05:03 PM   #8
Lop it off with the dremel. Try not to nick the flange area on the head because it won't be fun trying to get it to seal afterward. A mini hack saw may work too, but it'll be slow.
Post #11: http://www.saturnfans.com/forums/sho...d.php?t=180889
Video: https://www.youtube.com/watch?v=cy2ztwi8Tao
You'll just have to cut a bit more of the flat part out of the way than the video shows, as well as actually cut all the way to the head, if the crack isn't nice like his is (though I'd cut off the cracked part, and debur the end before sliding the hose further on to prevent broken bits from clogging the system).
Old 11-20-2016, 05:23 PM   #9
1993
Mine isnt cracked on the pipe like his is, its leaking between the plastic manifold and the head, but i figure if i have to mess with it, i may as well do the metal pipe mod so i wont have to later..
Old 11-20-2016, 10:01 PM   #10
1993
YES! post #11 that you posted above is how i want to do it. Can i still do it if it indeed does have the 1st design that bluesl2 mentioned above?
Old 11-21-2016, 08:50 AM   #11
1993
anyone
Leaky Coolant Inlet Plastic Intake Manifold 2000-2002 S-Series whitebluesc2 S-Series Tech 1 03-26-2015 06:58 PM
Gen 3 Plastic Intake Coolant Leak - Anyone tap head? porphyre S-Series Tech 12 09-15-2014 08:14 PM
Coolant leak under air intake JoyRiderJosh S-Series Tech 10 09-12-2013 12:16 AM
2001 SL2 Plastic Intake Coolant Line Repair td1238 S-Series Tech 10 10-12-2012 11:03 PM
leak in plastic area under upper radiator hose intake. technopop L-Series Tech 0 06-28-2007 03:00 PM
