Old 10-30-2016, 02:33 PM   #1
casterman
casterman is on a distinguished road
Default 2005 Ion sedan - only reverse - no forward gears
A family friend had his 2005 Ion sedan with an automatic towed to my shop because suddenly it lost all forward gears. If you put it into reverse it will engage properly and back up but if you put it in any of the forward gear locations absolutely nothing happens. I did not notice if it had a check engine codes but tomorrow I will put my OTC Nemisys on it and see what it shows. I did not check tranny fluid level because it was able to find reverse. Anyone experienced a problem like this?
Crazy John
Tulsa Oklahoma
Bringing the Dead back to Life
Add to casterman's Reputation
Rate the quality of this post and help casterman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
casterman is offline   Reply With Quote
Old 10-30-2016, 05:27 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: 2005 Ion sedan - only reverse - no forward gears
There are a couple common issues with the 4T40E transmission that cause the forward gears not to function. Read about them here.
2007 Ion 2 Quad Coupe 5-speed manual 176K miles
2007 Chevy Equinox LT 175K miles
Add to ruley73's Reputation
Old 10-30-2016, 07:25 PM   #3
casterman
thanks for the reply -- sounds like it's time for a trip to the salvage.
Crazy John
Tulsa Oklahoma
Replaced Shifter Solenoids in '08 XE and now all gears are forward, including reverse doublehelix Aura General 0 09-17-2013 09:08 AM
Hard Shift in forward gears maddo1ck S-Series Tech 18 04-05-2010 09:58 AM
sc2 reverse fine, no forward gears or neutral diy by default S-Series Tech 12 03-08-2009 07:11 PM
All gears are forward gears?! banana944 S-Series General 4 02-18-2009 08:51 AM
No forward gears 94stoner S-Series Tech 21 03-27-2005 03:45 PM
