Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay General
Old 10-26-2016, 11:25 PM   #1
besi
besi is on a distinguished road
Default Key stuck in ignition ,can't remove it.
parked the car and i wasn't able to remove the key from ignition,stuck in on position.now the battery is drained.
any idea what could be the problem ?thx
Add to besi's Reputation
Rate the quality of this post and help besi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
besi is offline   Reply With Quote
Old 10-27-2016, 10:31 AM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: Key stuck in ignition ,can't remove it.
id jump the car to get it running and play with the shifter to make sure its in park. im thinking ignition switch doesnt know its in park..
Add to onefunkar's Reputation
Old 10-31-2016, 07:42 PM   #3
besi
thanks for the answer,i bought a new battery because the old one was bad,but the key is still stuck,can't even turn the key.tried to put the shifter in every position but key doesn't move.
asked the dealer he said take it in ,but probably im looking at 800$ if they have to change the cylinder. wtf ?
where is the ignition switch is it easily accessible ?
Old 11-01-2016, 07:40 AM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
that seems like alot. im not sure if something has to be done with immobilizer key system if you replace lock cylinder. thinking maybe it would need new keys and programming. dealers like to charge alot for programming if they can.
06 Ion 3 stuck ignition lock cylinder - can't remove Choronodon Ion General 12 08-17-2015 09:17 PM
Can't remove the Key from the Ignition Switch zeissheadreggie Vue Red Line 2 07-14-2015 07:35 PM
Need ideas on how to remove stuck wheel bearing housing ericpell Vue Tech 7 05-01-2008 05:59 PM
Key stuck in ignition Scott Doscher S-Series Tech 13 03-01-2007 01:05 PM
Key stuck, very hard to remove key from ignition... Actaeon S-Series Tech 7 12-21-2003 12:08 AM
