Go Back   SaturnFans.com Forums > Site Information > Community Center
Old 10-16-2016, 08:48 PM   #1
gettingold
gettingold is on a distinguished road
Default timing?
i changed the timing tentionor and have timing marks set and #1 cylyder is all the way up, but no fire,,,i need help
Add to gettingold's Reputation
Rate the quality of this post and help gettingold reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gettingold is offline   Reply With Quote
Old 10-17-2016, 12:43 AM   #2
Default Re: timing?
Presuming you're asking about Saturn timing, you've managed to leave out some essential information. Saturn models start with the S-series then moves on to the L's, and Aura's, Ions, Outlooks and Vues. If you know your model, repost again in the model forum with car info, year/model/mileage/parts replaced/etc., so everyone will have an idea of your problem.
Old 10-17-2016, 07:50 AM   #3
billysvue
Default Re: timing?
all of the above and maybe you're 180 degrees off
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 10-17-2016, 10:05 AM   #4
gettingold
Default Re: timing?
sorry its a 2001 i300 v6 68000 miles
Old 10-17-2016, 03:04 PM   #5
Default Re: timing?
Either continue here or post over in the L-series tech forums to reach as many L-series owners as possible. Timing belt issues were already covered with excellent info in past threads with pictures. As mentioned, either timing is off about 180 degrees or something else is preventing the engine from running - either fuel or spark (presuming timing is correct and spark plugs are good). 4-stroke engines use 720 degrees of timing so top dead center is every other 360 degree revolution of the crankshaft before intake and exhaust valves are closed. This only takes care of mechanical timing with fuel injection and spark part of the EFI system. Ensuring mechanical timing is correct allows you move on to advanced EFI system diagnostics, figuring out whether fuel, spark both failed.
If you're knowledgeable enough to re-time an engine then you're aware intake and exhaust valves should closed at or before top dead center for cylinder#1. This presumes compression is good and the engine was running before the timing belt was replaced. If timing is correct, the next steps are diagnosing a fuel, spark or both missing.
Fuel can be checked easily from the fuel test valve over the top of the engine. With ignition on engine off, the fuel pump runs for two seconds to pressurize the fuel rail, enough to squirt fuel out the fuel test valve when the black plastic cap is removed and valve stem depressed. Cover the test valve loosely with a rag as 40-55 psi will shoot fuel. This only checks for fuel and pressure, not injectors. Spark is difficult to check but a work around would be spraying starting fluid into the throttle body and starting. Knowing fuel is manually sprayed into a throttle body should result in a brief engine run if spark occurs.
Did you check for blown fuses?
crank position for timing without removing the timing cover 03232001 S-Series Tech 9 10-03-2015 05:59 PM
sounds like the timing chain coming in contact with timing cover prioris S-Series Tech 3 12-08-2012 12:12 AM
timing chain sounds like it could be coming into contact with timing cover prioris Sky Tech 0 12-07-2012 09:31 PM
Help! - Timing Belt L81 - AC Delco -Rock Auto Kit - Timing Mark Question oldvue Vue Tech 5 09-16-2010 03:55 PM
Timing Chains, Timing Belts and Design Arrogance manualman General Saturn Discussion 82 03-04-2002 03:04 PM
