Old 09-02-2016, 05:55 PM   #1
driver8
driver8 is on a distinguished road
Default 2000 LS2 No fuel, no scanner communication after timing belt
So I have been searching on this forum for a few days with no avail. I was driving the car home one day and it died as I was getting off the highway, turns out the timing belt had broken. A month and a new set of cylinder heads later, I get the car back together but it won't start. It cranks, but there is no fuel pressure. I plugged in my OBD II reader and it gives a "no communication" error. The only lights that stay on the dash are check engine lights. I am so confused by this whole ordeal. I have read it could be the ECM, BCM, grounding issue but idk. It is a 2000 LS2 3.0l.
Add to driver8's Reputation
Rate the quality of this post and help driver8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
driver8 is offline   Reply With Quote
Old 09-02-2016, 08:34 PM   #2
Default Re: 2000 LS2 No fuel, no scanner communication after timing belt
What exactly do you mean "no fuel pressure"? If you sprayed starting fluid into the throttle body while starting, does the engine run or not? Let's not jump to any conclusions until several troubleshooting steps are performed. EFI systems are complicated but not with an overall perspective that engines still operate on the basic premise of needing air, fuel and spark. Presuming this engine can breathe (air) leaves fuel and spark testing. Are all fuses in good condition?
Old 09-05-2016, 12:43 PM   #3
driver8
Default Re: SOLVED 2000 LS2 3.0l no start, no fuel, no OBD 2/II power, no tach
Thanks for the quick response fdryer, but I solved the issue. My symptoms were I was getting no fuel pressure, no fuel gauge reading, no tachometer, no OBD II port power, but the vehicle would crank just fine. It would fire with starting fluid in the intake though. I checked ALL of the fuses, and replaced all of the relays. No luck.
After tinkering with it for a while I realized I skipped installation of the cylinder bank 1 GROUNDING BRACKET(the piece that holds part of the intake to the cylinder head) so I wasn't getting any ground. I decided to install the bracket. After the bracket was installed the car grounded out, but it only would last for a few seconds at a time.
After some more tinkering I checked the fuses again, alas ENG CNTL3 fuse (10amp) had fried as soon as I reconnected the battery. After replacing the fuse the car STARTED RIGHT UP, and I am now breaking in the new heads.
Long story short, the computer on top of the intake closest to the driver(has 2 big plugs on top) MUST BE GROUNDED properly
Old 09-05-2016, 12:47 PM   #4
driver8
If I could put SOLVED in the title, that would be nice as well
Old 09-05-2016, 02:47 PM   #5
Well done as you are the second member to inadvertently leave the ecm loosely mounted. This occurred several years ago to another member. After some maintenance was performed, he loosely remounted or found his ecm with only one mounting screw barely holding it in place. When it was mentioned ecm's need to be mounted to the engine securely, he found replacement screws. The engine started up.
2000 LW2, Timing Chain or Belt ??? tomcook L-Series Tech 7 06-08-2012 08:12 PM
no communication with obdII scanner ggriffin S-Series Tech 4 01-26-2012 10:49 PM
Help !! 2004 Vue No Communication with scanner stillalarm Vue Tech 3 09-14-2010 05:45 PM
V6 Timing Belt,2000 L-series s/street L-Series Tech 3 07-04-2007 01:49 AM
2000 LS2 Timing Belt Replacement aaront L-Series General 5 07-13-2006 02:10 PM
