Old 08-26-2016, 10:58 PM   #1
Lahms
Lahms is on a distinguished road
Default Vehicle lurches when reaches running temp
I got a 96 SL2 that I have been driving for 3 years now. Havent had any problems. Car is super reliable, 219k miles and still going strong... but, for a couple months now, the car jerks and lurches. But this only happens when I reach my normal running temp. It makes driving in town with a bunch of lights unbearable. Another symptom is the moment the car does its thing, I push on the clutch, the RPMs plummet to around 600-700 and sometimes even as low as 400. This is only for a brief second. The car idles just fine but accelerating is terrible. And during days when its hotter than 85 outside, its even worse. I dread driving home from work when its 100 outside. I do pop a p0404 code (EGR valve failure). I took the valve off the car, gave it a good cleaning with carb cleaner and such. Put it back on with a new gasket. Awhile back I thought it was the MAP sensor, replaced it and cleaned the hole it sits in. No joy. Does anyone have experience with this? Taking it to dealer/shop is the last thing I wanna do because I am confident I can fix this myself. Will I need to buy a new EGR valve. Bought a new engine coolant sensor and I am installing it tomorrow morning. Any insight would be VERY MUCH APPRECIATED!
Add to Lahms's Reputation
Rate the quality of this post and help Lahms reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lahms is offline   Reply With Quote
Old 08-27-2016, 11:23 AM   #2
billr
Default Re: Vehicle lurches when reaches running temp
If you have a scanner with live-data, you could check the MAP, EGR, ECT, and much more, without just throwing parts at it. The EGR valve (and other stuff) can be checked with an electrical multimeter, though, it's just more difficult to do.
Easiest to try with the EGR is to just block off the ports under it, see if that stops the lurching.
Add to billr's Reputation
Engine BARELY running after vehicle was parked. Help DawnR S-Series Tech 27 10-07-2015 04:44 PM
Loss of power when car reaches operating temp, transmission related? jushinator S-Series Tech 10 02-07-2011 07:50 AM
loss of power when car reaches operating temp.... Help needed jushinator S-Series General 67 02-07-2011 12:02 AM
00' Sl2 not hitting running temp WesB S-Series General 18 01-07-2011 03:39 PM
Vehicle running great, still change ECTS? Vue&SL1 S-Series Tech 14 12-04-2007 09:27 PM
