Old 08-13-2016, 06:34 PM   #1
kgershenson
kgershenson is on a distinguished road
Default Changed plugs now won't start.
2001 L300 6 cylinder.
I replaced the spark plugs which took a while on this model. The mechanic said there was a problem with either one of the coils on the coil pack or a plug. I replaced the plugs. One of the plug caps was difficult to come off but finally did. I put everything back together and now it will not start. I checked all of the fuses and everything looks good. There is no security light showing.
What should I do?
I would appreciate any help.
Add to kgershenson's Reputation
Rate the quality of this post and help kgershenson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kgershenson is offline   Reply With Quote
Old 08-13-2016, 09:26 PM   #2
Default Re: Changed plugs now won't start.
Did you re-check all wiring that was disconnected as both intake runners were removed before plugs were seen? The ecm, both coil packs, miscellaneous connections?
Old 08-14-2016, 11:11 AM   #3
Russet
2002 L-Series 3.0L Sedan
What should I do?
They're are held on by two reverse torx bolt and once those are off you should be able to pop them right out. And when you put them back in make sure you vacuum the tube so not dirt is in there before removing the plugs. Also check the plug at the coil pack it has to snap in. I know I got new one and they have plastic plug in the new coil pack that you need to take out so the plug fits in otherwise it won't connect.
Add to Russet's Reputation
Changed plugs to NGK V BKR4E-11 and wires to AC Delco : Car won't start foo S-Series Tech 3 07-18-2009 05:45 PM
2.2L - spark plugs changed Tom92SCm Vue Tech 0 07-29-2008 10:50 PM
changed plugs in my sc1 now no start poifect S-Series General 24 06-29-2005 01:41 AM
Changed spark plugs and wires, look at old plugs (pics) Chingon S-Series General 12 03-30-2005 02:42 AM
Anyone changed plugs on LW2 V6? swilroy L-Series General 4 10-25-2004 03:46 PM
