Old 08-10-2016, 09:33 PM   #1
toddsdonald
toddsdonald is on a distinguished road
toddsdonald's Avatar
1994 SC2
2009 AURA XE
Default What is causing this engine racket?
94 SC2 5 speed... Starts, runs and drives fine but just started making this racket... Any ideas? Something bouncing around in the cams maybe?
This is a link to a short video where you can see / hear the engine.
"https://drive.google.com/file/d/0B68MZskjuZroY29ncElLb1RIdVk/view?usp=sharing"
1994 SC2 5 Speed - Bright Red 83,000 miles
Add to toddsdonald's Reputation
Rate the quality of this post and help toddsdonald reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
toddsdonald is offline   Reply With Quote
Old 08-10-2016, 09:57 PM   #2
billysvue
Default Re: What is causing this engine racket?
SOunds like it will self-destruct in 5 seconds.
Valve train issues or worse( though that can be bad, too).
Park it and investigate.
Been starved of oil,now/ recently/ periodically?
OIl usage rate is( mi/quart)?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 08-11-2016, 10:54 AM   #3
hholbein
1997 SW2
It didn't seem your AC was running in the video, correct?
It sounds like you might have an issue with your timing chain. Maybe one of the guides bit the dust? You might try a stethoscope to see if the noise is coming from under the front of the valve cover vs. anything else attached to the drive belt.
Add to hholbein's Reputation
Old 08-11-2016, 11:58 AM   #4
billysvue
Self-destruct sequence in 5,4,3,2...
'17 Suby Forester
Old 08-11-2016, 12:06 PM   #5
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
Timing chain is getting close to coming through the cam cover.
1992 SC
1994 SW2
1997 SW2
others in my yard
Add to johnny95sl2's Reputation
Rate the quality of this post and help johnny95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnny95sl2 is offline   Reply With Quote
Old 08-11-2016, 12:19 PM   #6
I'd pull the valve cover off to check on the timing chain. You could probably wait another 10min of idling and whatever the issue is will create a nice window though... :/
Using air conditioning causing engine to stall? mike74 Vue General 11 08-25-2014 07:58 PM
Steering Column Racket Warren 2008 Vue 8 11-20-2011 09:08 AM
Air conditioner clutch racket flflashr S-Series Tech 8 11-16-2009 03:18 PM
Washing the engine causing multiple.... alegoric S-Series Tech 12 03-11-2009 02:08 PM
HELP! 92 SL2 engine racket OldGoatDJ S-Series General 7 06-27-2007 05:18 PM
