Old 07-26-2016, 07:32 AM   #1
yert37388
yert37388 is on a distinguished road
Default 2003 Vue 3.0 - cranks but will not start
Hello everyone, I have a 2003 Saturn Vue (3.0, auto, 212000 miles).
I have an issue with this car resulting in a crank but no start situation. This began a few weeks ago when the vehicle suddenly shut off while my son was driving. He was luckily able to coast to the shoulder and get it started and running long enough to get to a parking lot. We ended up trailering it home and it has not run more than a few seconds at a time since then.
My initial thought was Passlock because it will occasionally start and run a few seconds then shut off with the security light flashing. Unfortunately the flashing security light is inconsistent which led me to look further.
I though it might be the fuel pump but I can hear that running for a couple of seconds when the ignition is initially turned on.
Then after reading so many comments regarding the crank position sensor and the symptoms it gives I was sure that had to be my problem so I replaced that. Unfortunately there was no change.
Further research has let me to suspect that my worn key may be the culprit resulting in Passlock cutting off the fuel injectors. Shortly after the initial problem I had received the 14506 recall notice in the mail regarding the ignition key removal but it never dawned on me that could be my ultimate problem. Is it possible that this is the actual source of my issue?
I really hate to take this thing to the dealer for that recall only to have them 'troubleshoot' their way deep into my pocket.
I would be very appreciative of any help or advice you might offer.
Thanks, Trey in TN
Add to yert37388's Reputation
Rate the quality of this post and help yert37388 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yert37388 is offline   Reply With Quote
Old 07-26-2016, 10:34 AM   #2
Chazberry
Chazberry's Avatar
Default Re: 2003 Vue 3.0 - cranks but will not start
Where did you get the CKP sensor?
Add to Chazberry's Reputation
Old 07-26-2016, 12:13 PM   #3
far2grumpy
far2grumpy's Avatar
I've heard of an intermittent wire between ECM and engine MAIN RELAY ... a simple test is to remove MAIN RELAY (underhood fuse block) and put a jumper between sockets 30 and 87 (use relay bottom to identify).
Old 07-26-2016, 04:47 PM   #4
yert37388
Thanks for the replies!
The sensor is an AC Delco brand that I ordered from AutoWarehouse. It did cross my mind that i could have gotten a bad one but after it didnt fix my problem I checked the old one with an ohm meter and got a reading of around 950. That is within spec based on what I have read and apparently my first one was good to begin with so now I have two.
I will try that jumper wire and see what happens.
Thanks, Trey
Old 08-03-2016, 10:17 AM   #5
yert37388
Okay I did try the 87-30 jumper but there was no change in my situation.
In the interim I did email GM to inquire about the recall and described my issue asking if the recalled part might be my issue. I (finally) received a reply email from Buick support stating that they had decided that I should call their 800- number for support. I have not done that yet.
I guess that will be my next step (though I am less than hopeful for much support) unless anyone has any better advice/ideas.
Again, I appreciate your help.
-Trey
Old 08-03-2016, 11:14 AM   #6
Badmotorfinger
Badmotorfinger has a spectacular aura aboutBadmotorfinger has a spectacular aura aboutBadmotorfinger has a spectacular aura about
Ordinarily I'd say based on your description that this is classic CPS failure but you seem to have eliminated that possibility. So we move on...
I'm going to make the bold assumption your timing belt hasn't jumped a tooth considering your son was able to restart and drive after the initial stall.
I'm leaning towards a fuel related issue, clogged fuel filter, failing fuel injectors, etc. something that allows just enough fuel to fire the engine before stalling. The issue is the design of the intake manifold inhibits any simple testing of spark and fuel unless you have a strong desire to spend a couple hours removing the intake.
I would try this: spray a liberal amount of starting fluid into the throttle body and see if it runs for a very short time. If it does, you have a fuel issue and I would start at the fuel filter and move forward.
If it doesn't start, I would suspect an ignition issue and plan on removing the intake.
Hope this helps.
2003 Saturn Vue V6 3.0L
Add to Badmotorfinger's Reputation
Rate the quality of this post and help Badmotorfinger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Badmotorfinger is offline   Reply With Quote
Old 08-03-2016, 12:07 PM   #7
far2grumpy
far2grumpy's Avatar
The fuel pump has two common fail modes - one is low fuel pressure and the other is check valve allowing fuel to bleed back into tank during key off - resulting in hard starts.
I would check fuel pressure with key off - then after cycling key on - off - on at least three times.
The 3.0 fuel injection system expects to see 50 to 60 psi for proper operation.
I've found that if I see 0 psi in a 3.5 fuel rail (bad check valve) before first key on the pressure will increase by about 15 psi after key is cycled on and off one time ... another key cycle builds to 30 psi and third gives me 45 psi which is usually good enough for a smooth start.
Old 08-09-2016, 10:45 PM   #8
Badmotorfinger
Trey, did you ever get this figured out?
Ironically, my wife called me early this evening stuck on the side of the road. Similar symptoms as you described.
I was able to get it started with starter fluid; after a few seconds, it stalled again. I was able to start it again after leaving the key in the On position for about 10 minutes while I read the fuse section in the manual. It then stalled after about 10 seconds.
I have just checked fuses, but I'm leaning towards bad fuel pump and will be checking fuel pressure tomorrow.
Old 08-10-2016, 02:13 PM   #9
Badmotorfinger
Just to close my loop on this thread, on a hunch I had my battery tested. Battery was bad, just over 4 years old.
Car is running now.
Old 08-12-2016, 08:01 AM   #10
yert37388
Unfortunately I've had to back-burner this project in getting my son ready to head back to college. He just left so I'm going to start chasing the possibility of the fuel pump.
Glad you got your battery issue identified and sorted. I would never have considered that. Good info.
Thanks, Trey
Old 08-13-2016, 09:29 AM   #11
Badmotorfinger
Thanks, and best of luck with your troubleshooting.
If you haven't already and based on my results with similar symptoms as you described, double check your battery. Until I tested it, I was convinced the fuel pump had failed and was planning on dropping the tank this weekend.
Thanks, Trey
Old 08-13-2016, 03:19 PM   #12
M81
M81 is on a distinguished road
Ummm..... I have the similar problem.
The car was towed in to my house by a family member and he advised me a shop replaced a fuel pump and couldn't and still had crank no start.
I plugged in to it and I'm seeing a lot of loos communication codes.
If any one has a diagram of the BCM for a 02 saturn vue 2.2 I would appreciate it.
Good luck..
Add to M81's Reputation
Rate the quality of this post and help M81 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M81 is offline   Reply With Quote
Old 08-13-2016, 06:55 PM   #13
far2grumpy
far2grumpy's Avatar
Good luck..
We are sort of hijacking a 3.0 thread ... might be better to start a new one.
However. .. to give something to think about ... i don't know of single bcm wiring diagram listing all functions as its basically broken down by systems such as door locks, security & such. Can you list a few of the codes. They'd be good place to start.
2003 V6 vue cranks but no start Denny34 Vue Tech 4 01-20-2016 04:40 PM
2003 Saturn vue 2.2 2wd cranks but no start. Childebrandt42 Vue General 17 03-07-2014 12:41 AM
2003 Saturn cranks but no start tennhillbilly Ion Tech 17 02-06-2013 05:22 PM
2003 Vue 2.2L AWD cranks but wont start kenkab Vue Tech 28 12-01-2012 09:33 PM
2003 Vue Engine Cranks but won't Start KalDonatelli Vue Tech 5 08-03-2009 10:29 AM
