Old 07-26-2016, 12:57 AM   #1
sthadfield
sthadfield is on a distinguished road
Default 02 SL2 Auto Intermittent Stall
Hello all,
I'm fairly new to these forums but I figured this was the best place to start figuring out what is wrong with my car. 3 weeks back I purchased a used 02 SL2 auto with 125k. It has a coolant leak and the radiator fan has a few quirks but that's stuff I can deal with myself. What troubles me is that 3 days after buying it my car stalled when coming to a stop. It started right back up and ran perfectly well from there. It has stalled 5 times in 3 weeks. It only happens within the first 15 minutes of driving and when coming to a stop sign or light. It dies as if I took my foot off the clutch in a manual...in other words it doesn't downshift. I just changed the tranny fluid and it didn't help. I have a P0442 code, though I doubt it has anything to do with this. I also cannot hear anny hissing akin to a vacuum leak. No leaks detected other than the coolant. Remember, it doesn't do this at all once the car has run for a few minutes and when it does stall, it starts right up immediately. I have no idea where to start. Help?
Add to sthadfield's Reputation
Rate the quality of this post and help sthadfield reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sthadfield is offline   Reply With Quote
Old 07-26-2016, 04:27 PM   #2
billr
Default Re: 02 SL2 Auto Intermittent Stall
Do I understand correctly, the engine struggles mightily to keep the car moving as you brake it to a stop, the engine rpm comes down as the car slows until it is no longer running? That would indicate the transmission torque-converter clutch is not disengaging. I would use live-data to verify that, and check out some sensors. Do the brake lights work? I'm wondering if that is a crucial input to the PCM for determining that you are coming to a full stop and it's time to dis-engage the TCC.
Add to billr's Reputation
Old 07-26-2016, 06:37 PM   #3
There is a separate direct input to the PCM from the brake switch. To test it get to 45-60 mph on the highway and engage cruise control and after confirming cruise operation lightly touch the brake pedal, cruise should drop out before the car even starts to slow down.
Old 07-26-2016, 06:47 PM   #4
Does it stall if you shift into neutral when it just starts to bog down? I would be more inclined to suspect the Torque Converter Clutch solenoid at this point. Particularly if shifting to neutral prevents the stall.
Old 07-27-2016, 01:01 AM   #5
sthadfield
Thanks for the response. I started to stall again today and I put it into neutral with my foot off the gas and it prevented the stall. The cruise control functions properly. Is the solenoid a DIY job?
Old 07-27-2016, 07:30 AM   #6
Yes, butr do look up which bolts to take out. In the big search box enter valve body replace and that should find you all of the detailed info. Takes a couple of hours to do this.
Intermittent Not starting / Stall problem diablo2070 S-Series Tech 5 07-23-2011 08:59 AM
intermittent stall when put in park. please help or any info snakes Ion Tech 2 06-28-2010 06:26 PM
Tracking down intermittent stall lack of power jims73z S-Series General 24 11-01-2008 01:05 PM
Intermittent Near Stall jamman S-Series Tech 21 01-12-2007 05:35 PM
Cold Idle Issue Causes Immediate Stall (Intermittent) sharward S-Series Tech 6 07-03-2006 01:56 AM
