Old 07-20-2016, 12:12 PM   #1
jhervey
jhervey is on a distinguished road
Default locating the pcv valve on my 2008 outlook
Sorry if this is a repeated question but im trying to locate and change the pcv valve on my 08 outlook, and just cant seem to find it. Any help or pics of location is greatly appreciated!!!!!!
Add to jhervey's Reputation
Rate the quality of this post and help jhervey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhervey is offline   Reply With Quote
Old 07-20-2016, 02:10 PM   #2
Default Re: locating the pcv valve on my 2008 outlook
My '03 L300 doesn't use a pcv valve. GM decided to do away with the extra parts and fittings by 'asking' engineering to modify the engine ever so slightly to channel crankcase gases back to the intake manifold or throttle to accomplish the same effect, having the engine draw crankcase gases back into the engine intake for recycling/emissions purposes. No more pcv valve. I suspect most, if not all vehicles after 2000 reconfigured engines to eliminate the pcv valve.
Old 07-20-2016, 03:53 PM   #3
waiter21
2003 VUE 2.2L
On my 2003 2.2L 4 cyl, the Crankcase in ventilated directly into the intake manifold. If your engine has a lot of oily blowby, it could easily plug up the hole in the manifold and the head..
Pull out your oil dipstick, put your finger over the dipstick. It should be pulsing, but really shouldn't blow your finger off the hole.
This is a photo of my intake manifold with new o-rings. The PCV is the small blue o-ring in the middle.
Add to waiter21's Reputation
Help with 2008 Outlook XR dmcomm Outlook General 2 07-20-2016 12:17 PM
2008 Outlook Overheating Jarrod Outlook General 2 06-11-2010 06:48 AM
Disappointed in 2008 Outlook FARPAR Outlook General 7 04-27-2009 08:04 PM
new 2008 Outlook XR photos yogi Outlook General 8 02-25-2008 09:48 PM
2008 Outlook Pricing fperez728 Outlook General 5 06-14-2007 10:17 AM
